Old 02-09-2011, 01:51 PM
darkraven72 darkraven72 is offline
Vehicle: 2008 Dodge Ram 1500
Rep:62
darkraven72 will become famous soon enough
Default Anyone running 2wd with 6" lift and 295/70 18's?
Trying to narrow down my wheel/tire choices and I noticed this tire size. I want to run either terra graps or trail graps in 295/70 18 on Fuel Octane 18x9.
Anyone have any comments or pix to share? Thanks.
Old 02-09-2011, 04:07 PM
Rep:1625
I've only seen that size tire with a leveling kit installed, hopefully someone else can help you out.
Old 02-10-2011, 03:06 AM
Rammin's Avatar
Rammin Rammin is offline
Vehicle: '03 Dodge Ram 1500 2wd
Rep:44
Rammin is on a distinguished road
So roughly a 34"x11.6" give or take. Might be ok with a 2wd but still on the small side. Depends on what look and style you're going for ya know?
Old 02-11-2011, 12:10 AM
Rep:62
OK, scratch that. I am seriouly dissapointed the Pro Comp doesn't make a wheel to fit my needs, but I found this one:
I want to put Pro Comp Xtreme At's in 35x12.50x18 on Eagle 063 18x9. They have the 4.5" backspace that I need. Of course that center cap will have to get powder coated to match.
Hopefully it will have a similar look to this:
Old 02-11-2011, 03:01 AM
Rammin's Avatar
Rep:44
Much better. That would look great!
Old 02-11-2011, 10:46 PM
ScatPak07's Avatar
Rep:970
Yea a 35" should fit with a 6" lift. You have to see it compared to a 4x4 since all the info on here is mostly for them. The 2wd truck sits lower then a 4x4 from the factory so a 6" lift for you will be around a 4" for a 4x4. I just wanted to say that....really for no apparent reason.......I dont know!!! haha.....I guess for future reference?????
Why not look at CST? They make a 7" lift for your truck and they are a really good company.
There is a 12" lift kit for the 2wd Ram. I am not sure which company that was...may even be CST. That would be SWEET!! You can fit some 38" tires if you wanted to haha! Maybe even 40s!
It really sucks that the 2wd trucks can go bigger then the 4x4s. Stupid front diff!!!
