Old 02-09-2011, 02:45 PM
OregonTRX4's Avatar
OregonTRX4 OregonTRX4 is offline
Trim Level: 1500 TRX4
Rep:16
OregonTRX4 is on a distinguished road
Default Differential fill plug
How long has dodge been using these rubber plugs? I was kind of shocked to see such a thing. They must be adequate at keeping water and debris from getting in? Do they need to be replaced often? Also, I was reading about low diff fluids and while checking my rear it was slightly below the fill plug. I am guessing it should be level with the plug? Didn't find the front plug yet after a quick look. What fluid do they take and should I use the same brand as the factory? Thanks.
Old 02-09-2011, 03:14 PM
Rep:1909
I've never replaced one of these plugs or seen a problem with water intrusion. The fluid level should be about 1/4" below the plug level.
Old 02-09-2011, 07:51 PM
CHVYKLR's Avatar
CHVYKLR CHVYKLR is offline
Vehicle: 2009 Ram Crew 2WD
Trim Level: Lone Star
Rep:252
had my '95 wrangler for 14 years and never had a problem with them
Old 02-09-2011, 07:59 PM
RansRAM's Avatar
RansRAM RansRAM is offline
Addicted to the Z
Color: PX8 Black
Rep:2471
Smile
^^^^ That's good feedback, I popped mine off to take a look and it's just as RamTech said, 1/4" below the plug level. Use the same as factory, Here's the specs from the service manual:
Rear
MOPAR® Synthetic Gear Lubricant SAE 75W-140 (MS-8985).
Limited-Slip Rear Axles require the addition of 118 ml (4 oz.) MOPAR® Limited Slip Additive or equivalent.
Front
GL-5 SAE 75W-90 (MS-9763) or equivalent.
Old 02-09-2011, 09:14 PM
Ram15002ndgen's Avatar
Ram15002ndgen Ram15002ndgen is offline
Vehicle: 97 Ram 1500
Trim Level: Laramie SLT
Rep:55
Ram15002ndgen will become famous soon enough
My 97 has the plastic plug and it's still as good as new. They are hard to get out so be careful not to tear it. Once ripped or torn you'll need to replace it. They do the job just fine, you have nothing to worry about.
www.beatcraigslist.com - for posting dangers & secrets
Old 02-12-2011, 09:03 AM
donn12 donn12 is offline
Vehicle: 09 Ram
Trim Level: TRX
Rep:15
donn12 is on a distinguished road
How ofter is it supposed to be checked?
Old 02-12-2011, 09:13 AM
Rep:1909
Checking the level every oil change is a good idea.
Old 07-29-2011, 07:16 PM
RansRAM's Avatar
Addicted to the Z
Color: PX8 Black
Rep:2471
Just checked mine again and noticed that it is a bit lower than the 1/4" now. No obvious signs of fluid loss. Is this normal ? I added some oil, a few ounces to get it back up. Now I'm thinking of replaceing the fluid with some new synthetic, advice please.
Old 11-01-2011, 08:10 PM
lifted04 lifted04 is offline
Vehicle: 2004 ram
Trim Level: 1500
Color: patriot blue
lifted04 is on a distinguished road
when i pulled my plug off my rear diff it shot oil out , a decent amount. i have no idea how it would of got that full, i had just drove the truck but i dont think that much would of came out. i just got the truck 6 months ago so i am doing all fluids and i went to check it and this happened
Old 12-26-2011, 12:04 AM
Speed 1B Speed 1B is offline
Vehicle: 2011 Ram Sport 4x4
Trim Level: Loaded Sport
Speed 1B is on a distinguished road
Eventually the plugs get hard and brittle over time. When you see some wetness around the plug its time to change it. Probably 10 yrs or so.
5.2/5.9 Misfire TSB 18-48-98 RamTech Dodge Ram Knowledge Base 3 06-22-2014 07:45 AM
How to decipher axle codes? BigSwede 2011 Dodge Ram Forum 6 01-07-2011 05:37 AM
Rear Differential fluid amount downonmonday 5.7L V8 Specific Topics 8 07-20-2010 04:27 PM
Rear end confusion dirtsurferus Suspension 6 12-30-2009 08:25 AM
