United Radio
Old 02-09-2011, 04:36 PM
southpaw5m's Avatar
southpaw5m southpaw5m is offline
Vehicle: 2003 dodge ram 4.7L
Color: Patriot Blue Pearl
Rep:23
southpaw5m is on a distinguished road
Default LED turn signal problem
Hey just wondering? I installed LED turn signals with the load resistor and am still getting occasional, well more than occasional "lamp out" signal. It's getting very very annoying. All wiring is good. Has anyone else had this problem? Are the bulbs front heavy or not connecting tightly at the base of the bulb? It sometimes starts hyper-flashing after turning on the turn signal, but not every time. Any help would be great
Old 02-09-2011, 04:57 PM
Rep:1824
When it starts flashing rapidly, are any of the turn signals inoperative? Loose bulb sockets aren't terribly uncommon, particularly in the tail light assemblies.
Old 02-09-2011, 05:02 PM
southpaw5m's Avatar
Rep:23
You know, one of my LED reverse lights was really loose and the connection in the harness needed some adjusting for it to work right. Could that do it?
Old 02-09-2011, 05:04 PM
Rep:1824
It's possible. If the bulb were losing contact, it might drop the circuit resistence enough to cause the problem. You should also recheck the connections on the resistor you installed.
southpaw5m's Avatar
Rep:23
And you know my regular front turn signal works fine but the LED one is causing occasional hyper flashing, It could just be the design or the LED one is skinnier at the connection. I'll try to tighten it up a little and see what happens
Old 02-09-2011, 05:07 PM
southpaw5m's Avatar
Rep:23
I'll unwrap the wiring and see if the connection is still soldered good and tighten the bulb connection. Thanks for the input, it's getting really annoying
Old 02-09-2011, 06:03 PM
TALLA's Avatar
TALLA TALLA is offline
Vehicle: 2008 1500 Dodge Ram Quad Cab
Trim Level: RAM 1500 Big Horn
Rep:56
TALLA will become famous soon enough
Send a message via MSN to TALLA
hello and welcome to the forumZ
2006 Chrysler 300C 5.7 Hemi
2008 Dodge Ram 1500 Quad Cab Big Horn 5.7 Hemi
Old 02-09-2011, 06:24 PM
platinuminjected's Avatar
Vehicle: 2009 dodge ram 1500
Rep:713
try searching in the electrical section and you will prolly find the answer to your problem!!
Problems with my turn signal lights. kjtc6 Electrical 20 06-06-2013 09:02 PM
Turn Signal Issue jayhkr Electrical 13 07-29-2012 11:24 PM
Trailer turn signal not working EBK142 Electrical 10 03-19-2012 08:52 PM
Turn signal acting off jayhkr Electrical 5 07-29-2011 04:59 PM
Turn signal problem JasonBuckner Electrical 6 01-29-2010 09:14 PM
