Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Electrical
Old 02-09-2011, 09:10 PM
Matt1924's Avatar
Matt1924 Matt1924 is offline
Vehicle: 1999 Dodge Ram
Trim Level: SLT Lariat
Color: Red/Silver
Matt1924 is on a distinguished road
Angry No Odometer
Hey guys, thanks for reading. I recently picked up a used 1999 ram with a 5.9l 2wd. This is my first Dodge. So far I am pleased with just a few unpleasant exceptions:
-About one hundred miles after I purchased the truck, the speedometer,odometer stopped working. Also my ABS and check engine lights came on. This affected nothing mechanically, it ran sound. After some research I learned that this could be contributed to a faulty speed sensor. So I replaced the one on the transmission and on the differential. I discon'd the battery for about ten minutes, and nothing changed. Let it sit overnight and the next morning it was all well. Ran for two days without issue. This evening it struck again. Abs light is on and the speedo and odo are not functioning. Anyone had this issue? Any help would be greatly appreciated, I'm kinda bummed with these issues especially since I just picked up this truck last week. Thanks!
Old 02-09-2011, 11:13 PM
Get the computer scanned for the trouble code and we'll be more than glad to help ya out .
Old 02-10-2011, 07:15 AM
Matt1924's Avatar
Color: Red/Silver
Thumbs up
Thanks, I'll swing by autozone later today and see what they are.
Old 02-10-2011, 07:00 PM
Matt1924's Avatar
Color: Red/Silver
Hi, just got back from Autozone, and the code p0500 popped up. Vehicle speed sensor, this is the same one that came up last week before i replaced it. Since its located on the diff, might very dirty gear oil cause it to mal? I went ahead and got a new gasket and some oil, gonna change it tonight see if that helps.
Old 02-19-2011, 12:01 AM
gwtaz gwtaz is offline
Vehicle: 1998 Dodge Ram 1500
Rep:35
gwtaz is on a distinguished road
I've had my used 1998 1500 for about a year and that was the first things I fixed. Rear diff. speed sensor replacement, $35 and driveway elbow grease. MIL went off, ABS light went off, speedometer & odometer started working and the truck stopped stalling out at stop signs. Seems to be very common problem.
Old 02-27-2011, 08:55 PM
dodgedaddy dodgedaddy is offline
Vehicle: 1999 dodge ram slt laramie
Color: burgandy and silver
dodgedaddy is on a distinguished road
Im having the same problem and I only have 98,310 miles on it
Old 02-27-2011, 10:23 PM
Resident Technician
Rep:1909
It could be a wiring, PCM or ABS problem but impossible to say without running the diagnostics on the systems.
Old 04-22-2011, 01:11 PM
Va5.94x4's Avatar
Va5.94x4 Va5.94x4 is offline
Vehicle: 2001 Dodge ram
Color: Tan
Va5.94x4 is on a distinguished road
this just happened to me today. have you figured out how to fix it yet?
Country Girl shake it for me
Old 04-27-2011, 10:09 PM
kawi348 kawi348 is offline
Vehicle: 2001 Dodge Ram
Trim Level: Lariat
Color: Maroon
kawi348 is on a distinguished road
Same thing happened to me..I bought the truck with 57,000 miles on it. Its a 5.2L and at around 65,000, crap started going out. Now I am having the same exact problem.
Old 04-27-2011, 11:42 PM
Va5.94x4's Avatar
Color: Tan
i just got mine fixed today. something came loose in the fuse box under the hood which caused some over heated and burn a wire cause my gauges not to work. might not be a problem for you but worth taking a look at.
Trip Odometer rich1500 2010 Dodge Ram Forum 13 08-28-2010 09:17 AM
Odometer question Dieselkiss Body & Interior 3 03-01-2010 07:12 PM
Odometer crazy!! gcr Dodge Ram General Discussion 3 07-31-2009 12:41 AM
2004 odometer bobd70 Dodge Ram General Discussion 2 07-12-2009 09:40 AM
Odometer US/Metric PhilippM Electrical 0 05-19-2009 03:04 AM
