Old 02-09-2011, 08:39 PM
Gossage55 Gossage55 is offline
Gossage55 is on a distinguished road
Default Cold air intake
I put in a Spectre 9931 Cold Air Intake in my truck. It has a heat shield box that surrounds the cone filter so it can get more cold air in from the fender and not get warmer air from the engine. I was told I should remove the heat shield box because it will actually be getting more colder air. It was designed to isolate the filter so it gets cold air so I figured removing it would defeat the purpose. Any thoughts?
Old 02-09-2011, 10:09 PM
I still have my shield around my K&N . Personally , I'd leave it on .
Old 02-09-2011, 10:10 PM
toddrod's Avatar
toddrod toddrod is offline
Vehicle: 2001 Dodge Ram
Color: Yellow
Rep:55
toddrod will become famous soon enough
Keep the heat shield on it! I made my own intake which doesn't have a heat shield, and it gets pretty warm in that engine bay. Besides the shield serves a dual purpose as it helps funnel cooler air and it will to some extent protect your air filter from contaminants that could go into your engine bay from underneath. If you do any off-roading and playing in the mud it will protect the filter from being badly clogged and reduce the amount of time spent cleaning that filter.
Old 02-09-2011, 10:16 PM
I kinda figured there was a reason they manufactured it the way they did...lol...I'll just leave it in place then. I dont do any off roading but it has stayed really clean thanks to the heat shield. I just wanted to improve performance and fuel mileage-after all, that's the reason I got it in the first place....Thanks for the replies guys!
Old 02-21-2011, 07:00 PM
MBCJim MBCJim is offline
Vehicle: 1999 Dodge Ram
Color: Green
MBCJim is on a distinguished road
I also recently installed the spectre kit and have a question for you about your install. How did you handle the breather hose not reaching the far side of the block?
Old 02-21-2011, 09:24 PM
That seems to be a problem with the Spectre cold air intake. I'm not sure why they even included that short hose in the box. I ended up going to Lowes and purchasing a longer hose that was (I believe 3/8 inch inside diameter) in order to connect it. It only costs a couple bucks, if that. Overall, I am really happy with the intake though.
Old 02-22-2011, 06:16 AM
Color: Green
I did basically the same, Napa was closer for me. I routed mine behind the plenum, where did you route yours?
Old 02-22-2011, 10:48 AM
I believe I did the same thing. I purchased 2 or 3 feet and it was exactly enough to make it fit because I didn't measure before I bought it but I made it work.
Old 02-22-2011, 05:12 PM
Color: Green
Yeah spectre finally emailed me back today...apparently their tech department doesn't work Friday through Sunday or holidays. The gentleman offered to send me a 32" hose but I declined.
Old 03-18-2011, 09:40 PM
frealz13's Avatar
frealz13 frealz13 is offline
Vehicle: 2001 ram 1500 4x4
Trim Level: slt laramie
Color: blue silver
frealz13 is on a distinguished road
Default hose
the hose goes to the breather not the pcv valve the hose should fit and i would leave the box the intake tube mounts to it.when that plastic piece that attaches to the throttle body gets hot in the summer it might wind up warping or pulling off the tb.
-PAT-
Dirt road + Dust + Cold Air Intake tocou Dodge Ram 4x4 - Offroad Discussion 7 02-02-2011 02:49 PM
2009+ Hemi Ram MOPAR cold air intake chithead Dodge Ram Parts and Accessories for Sale - Trade - Want To Buy! 9 02-01-2011 09:10 PM
How to: Clean Your Cold Air Intake 98sst Dodge Ram Knowledge Base 10 05-27-2010 10:26 PM
Cold air intake newbie Custom Dodge Ram Performance Mods - Engine - 5.9 Liter V8 9 02-08-2010 08:13 PM
