Old 02-09-2011, 09:41 PM
KarmasRAM KarmasRAM is offline
Vehicle: 96 Ram
Rep:13
KarmasRAM is on a distinguished road
Default Going agains the grain
Well here I am looking at all the nice shiny truck with their big rims and little skinny rubber band tires and thinking hmmm how can I stand out from this crowd So here it is I have a set of 15x10 rims here from another project that wont be getting used now but they would look really slick with a set of 31x10.5 tires on there I kow that they will clear the rear drum brakes but with they fit around my front disks and calipers without any major issues??
Old 02-09-2011, 10:52 PM
jcasey10's Avatar
jcasey10 jcasey10 is offline
Vehicle: 2002 Dodge Ram
Trim Level: SLT Quad Cab
Rep:869
I have a good feeling 15" isn't enough clearance. I've always seen people stay away from that and go 16" and up
Old 02-10-2011, 11:42 AM
67Polara's Avatar
67Polara 67Polara is offline
Vehicle: 2001 2500 ext cab long bed
Trim Level: sport
Rep:77
67Polara will become famous soon enough
pull your current rim off and measure yor rotor and see how it would fit in the new rim.
"I'm your huckleberry" (Doc Holiday)
Old 02-12-2011, 12:20 AM
ScatPak07's Avatar
Rep:970
The stock rotors are a 12" I believe. I am getting the SSBC brake upgrade for the front of my '07 Ram and those rotors are 14". that is what leads me to believe they are a 12" stock.
I was just wondering why you want to go with a small tire? You can fit up to a 33" tire if you wanted to. Rams with a stock 20" rim have a close 33" tall tire
Old 02-12-2011, 01:45 AM
platinuminjected's Avatar
Vehicle: 2009 dodge ram 1500
Rep:713
i dont think that would look right at all!!!!!! thats wayyyy too small for our trucks
Old 02-12-2011, 04:05 AM
Rammin's Avatar
Rammin Rammin is offline
Vehicle: '03 Dodge Ram 1500 2wd
Rep:44
Rammin is on a distinguished road
My stock 17" wheels and 31's are tiny on my truck
Old 02-12-2011, 06:20 AM
Vehicle: 96 Ram
Rep:13
My curant tires are 285/75 R16 if I did the math right theat thould be about 31.9 inches when they were new right now they are worn out but they so they are closer to 31 and they look big in the second GEN wheel opening
My personnal preferance is lots of tire with little Rims
mybe I should go with the 15 inch rims and a 32 as it should fit but Im not sure if a 33 will fit when I turn full turn
Old 02-12-2011, 01:11 PM
curt4816's Avatar
curt4816 curt4816 is offline
Vehicle: '11 Dodge Ram Crew
Trim Level: Laramie 4X4
Rep:178
curt4816 has a spectacular aura aboutcurt4816 has a spectacular aura about
LOL, if you do the math, 31" tire on a 15" rim is the same as a 33 tire on a 17 rim. or a 35 on a 20" rim. not really against the grain. just less expensive. what every you pick, im sure it will look good. make sure to post pics.
Mods: H&S Mini Maxx w/ egr and dpf deletes
Old 02-12-2011, 02:51 PM
Vehicle: 96 Ram
Rep:13
Your right not really against the grain as far as over all size goes
But every one seems to be going bigger and bigger with the RIM size and I wanna go smaller thats all
Old 02-12-2011, 03:43 PM
Rammin's Avatar
Rep:44
I think it all depends on the truck really. I think that a lot of newer trucks look weird with small wheels and big tires but the older 2nd gen trucks looks good with up to 17" wheels and big tires.
Wood Grain Center Radio Bezel watterson 2009 Dodge Ram Forum 21 06-24-2011 03:56 PM
Covering up the Door WooD Grain JBSPartans05 Dodge Ram General Discussion 0 05-24-2010 09:27 AM
