What tire size? - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 02-10-2011, 03:07 PM
Elkriver1500 Elkriver1500 is offline
Vehicle: 2003 ram 1500
Color: grey
Elkriver1500 is on a distinguished road
Default What tire size?
I have an 03 1500 leveled. What is the bigest tire I can fit on 18" wheels?
Old 02-10-2011, 03:42 PM
Color: grey
Thinking about doing Hankook rf10 in a 325/60/18 and maby put on 1/4" spacers
Old 02-10-2011, 03:43 PM
foxcrazy90's Avatar
foxcrazy90 foxcrazy90 is offline
Vehicle: 2008 dodge ram 1500
Color: electric blue pearlcoat
Rep:584
foxcrazy90 is a name known to allfoxcrazy90 is a name known to allfoxcrazy90 is a name known to allfoxcrazy90 is a name known to allfoxcrazy90 is a name known to allfoxcrazy90 is a name known to all
i would say 295-70-18 which is a 34"
or have seen some guys on here running 35's
alot depends on the wheels backspacing and offset!
NEIL KELLEY
2008 ram 1500 bighorn 4x4
2 1/2 level lift--hella 500ff grill lights--17x9 centerline grizzly-305-70-17 nitto terra grapplers--front air valance removed--tinted windows--custom audio system clarion vz401 head unit--pioneer 4channel amp and class D mono amp--memphis mclass door speakers--clarion dash speakers--kicker subs
Old 02-10-2011, 03:52 PM
Color: grey
The hankook 325/60 is 33.3x12.6
Old 02-10-2011, 09:45 PM
jcasey10's Avatar
jcasey10 jcasey10 is offline
Vehicle: 2002 Dodge Ram
Trim Level: SLT Quad Cab
Rep:869
I'd go with a 33" tire since it's leveled. You may not even not need spacers with those 325's. There was a guy on here that leveled his truck with 35's and only needed a spacer.
jcasey10's Avatar
Rep:869
http://www.RamForumZ.com/showthread.php?t=68819
It's stickied at the top of the Wheels&Tire section
Old 02-11-2011, 07:12 PM
platinuminjected's Avatar
Vehicle: 2009 dodge ram 1500
Rep:713
i would either go with a 33 or a 35 it depends on how you want it to look and if you like wheel gap or not
Old 02-11-2011, 11:24 PM
ScatPak07's Avatar
Rep:970
You should stick with something under a 34" tire. With just a leveling kit the best look is with a tire around there. if you go with a 35" tire then you will have a "stuffed" look, which IMO looks kinda ghetto. Just seems like it is unfinished to me if you cant see the wheel well. I will probably get attacked for that comment haha
the other thing is with a stock wheel you will most likely need to look at getting a wheel spacer. the other thing which is better but more expensive is an aftermarket wheel with a negative offset. You will need this only IF your tires rub on the suspension components. It is just that the tire is really wide
Old 02-12-2011, 12:42 PM
Color: grey
I do have aftermarket 18" wheels on it but I dont know the offset. I bought it that way.
Suspension, Tire, and Wheel Guide 57Hemi08 Dodge Ram Wheels And Tires 169 07-19-2017 01:26 AM
Tire Pressure Monitoring System Explained RamTech Dodge Ram Knowledge Base 4 03-14-2011 04:29 AM
What tire size for 24 inch rims wesr52 2010 Dodge Ram Forum 7 02-09-2011 06:33 PM
Tire Size 01RAMguy Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 4 04-21-2010 11:37 PM
1.5 in lift max tire size RacerXisRad Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 1 11-22-2009 08:24 PM
