Old 02-10-2011, 04:49 PM
Briansal's Avatar
Briansal Briansal is offline
Vehicle: 2010 Ram 2500
Trim Level: TRX4
Color: Crystal Black Pearl
Rep:62
Briansal will become famous soon enough
Default Leveling the 2500
Has anyone leveled a 2010/11 2500 with the solid front axle? Do you still need an alignment since there are no a arms or drive shafts changing angles? Are there any other things to be concerned about?
Old 02-10-2011, 07:28 PM
jeepinoutwest jeepinoutwest is offline
Vehicle: 2011 Ram 2500
jeepinoutwest is on a distinguished road
I did my 2011 2500 last sunday. HBS told me I need to get the truck aligned, which I will do after new tires, which will hopefully be this weekend. I can check back with you to tell you just how much out of align my truck was. No pics yet either, waiting for tires.
Old 02-10-2011, 09:25 PM
Vehicle: 2005 Dodge Ram 2500
Color: Mineral Gray
Rep:177
Pretty common mod. I highly recomend Hell Bent Steel leveling kits. Great quality great price.
You dont "have" to get the truck aligned. A buddy of mine installed his and hasnt touched the front end since. I got an alignment after I put one on just cause the truck pulled to the left a little bit. They say you dont get the full 2" or 2.5" till you do get it aligned, wish I would have measured :/
I would see how the truck feels to you and then go from there.
Old 02-10-2011, 09:33 PM
I bought the 2" kit, and I got a full 2" in lift. The truck steers perfectly straight, but since im spending over $1000 on 4 tires I think I'll get the truck aligned to ensure they last as long as possible.
Old 02-10-2011, 10:45 PM
buckchaser91 buckchaser91 is offline
Vehicle: 2006 dodge ram 2500
Trim Level: slt thunderroad
Rep:40
buckchaser91 is on a distinguished road
what size tires are you going with?
Old 02-10-2011, 11:06 PM
ScatPak07's Avatar
Rep:970
Ya you guys should be gettign alignments done. The truck could drive straight but things can be off. I guess they are your trucks you can do what you please..good luck with everything!
Old 02-11-2011, 12:49 AM
Briansal's Avatar
Trim Level: TRX4
Rep:62
Is there a need for the maxxlink anti sway bar end links
http://www.hellbentsteel.com/dodge-r...maxxlinks.html
Old 02-11-2011, 07:17 AM
I am going with 35s" if they will fit with my 2" lift AND my plow set up so I will have to have tires fitted with the plow on. If not I will be going with 295s.
Second, as far as Maxi-links. I called Julie from HBS, here's the deal. They are the exact same size as the OEMs, just beefier. They are more meant as a replacement for worn out links. Since my truck is new I didn't install maxilinks as my OEM links are brand new as well, but did install a sway bar drop kit which I posted pics of on a very recent thread in this section.
Old 02-16-2011, 05:24 PM
Big Ed Big Ed is offline
Big Ed is on a distinguished road
I was thinking of swapping Power Wagon Front springs into my 2010 Laramie 2500. These springs should level the front end and will actually have the performance attributes of the PW spring rates.
2010 Dodge Ram 2500, Laramie,Crew Cab,Hemi,4X4.
Old 03-07-2011, 06:26 PM
Well I decided to go a different route. Rather than installing PW springs I ordered a level kit from Carli. It includes new springs, longer end links, new shocks, and I ordered an adjustable track bar from them. Carli is pricey but from what I've read they are real good. I also ordered up some 295/70R17 Hankook Dynapro ATM's to mount on my factory rims. I throw some before and after pice when I do the install.
Vibration around 2500 rpms lucidanomaly Newbie Checkin! 14 04-25-2012 01:15 AM
2010 Dodge Ram 2500 TRX4 Leveling Questions.. Powerback73 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 12 02-26-2011 10:13 PM
Quoted $1373.50 for alignment after Installing Leveling Kit doozy Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 12 11-01-2010 10:20 PM
Dodge Ram K&N 1500 2500 3500 Ramrob Dodge Ram Parts and Accessories for Sale - Trade - Want To Buy! 16 03-21-2010 11:50 AM
Tires for 2500, need advice Raynval Dodge Ram Wheels And Tires 4 02-02-2010 06:23 PM
