question about wiring lights to overhead console? - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Interior and Exterior Lighting
Old 02-10-2011, 06:50 PM
strafen's Avatar
strafen strafen is offline
Vehicle: "Beast" - '09 Ram 1500 4x4
Trim Level: Laramie - Crew
Color: Inferno Red Crystal / Lgt. Greystone
Rep:42
strafen is on a distinguished road
Default question about wiring lights to overhead console?
ok i have a question here.... couldnt find anything on it.
has anyone figured out how to re wire the 3 garage door openers to operate offroad lights or anyother mod that requires a switch?
i know its kinda wierd thing to do, but i dont have a garage, and i think that would be a handy place to have your lighting, exhaust cutout or other mods.
if the current switch cant run anything else, i might just look into replacing them with toggle's or somethin else.
i didnt get as much back this tax time so bout all i can afford for now is some lights behind grill and upgrade halogens while im tearing into grill. no HID's for me yet, still havent seen a set in person to decide.
X'd seatbelt minder, 13" radio antenna - black, more to come.
Old 02-10-2011, 07:30 PM
APSTRAM's Avatar
APSTRAM APSTRAM is offline
Vehicle: 2016 Ram 2500 Crew Cab 4x4
Rep:89
APSTRAM will become famous soon enough
My console has a blank plate were the 3 buttons would be and mounting switches to that may be easier than making the home link switches work as a light switch.
Maybe you can get a hold of just that piece and sell the home link set up to some one who could use it or better yet have them send you the blank piece as part of the deal.
Old 02-11-2011, 03:01 PM
Crash Crash is offline
Vehicle: 2016 Laramie Longhorn Limited
Trim Level: Laramie limited
Color: Black crystal pearl
Rep:404
Let us know if you figure a way to make this work. If I could use one switch for my garage and could use the other two for something else it would be awesome. It never even occurred to me to try it.
Old 02-11-2011, 04:55 PM
Rep:2968
I did not think about using the overhead console for anything, i use the first switch for my garage door opener, that leaves the other 2
Behind the 2 courtesy lights, i installed a external speaker for my CB radio
i put my 2 extra switches on my front dash console, they are for my external lights & auxiliary gas tanks pump
[IMG]
another place to consider is right below your climate controls, the panel reads RAM on it as seen in the pix, that panel is used for the heated seats & steering wheel switches, when you have that option, so it is ready for any switches that you may wish to add.
[IMG]
Old 02-11-2011, 05:06 PM
dodgeguy's Avatar
dodgeguy dodgeguy is offline
Vehicle: 2000 Dodge Ram 1500
Rep:61
dodgeguy will become famous soon enough
Dude.. That's GENIUS!
I don't have garage door openers on mine, so I never thought about it.
But you should be able to rewire them so it works.
You'll have to get in behind the switches and find where they run to.
If they run down to the fuse box, you just need to clip the wire (or splice the new wire into the old wire, in case you ever want to be able to use that switch as a garage door opener again; just make sure you don't program that switch to anything!) after the fuse and run a new wire off of that to your lights or whatever.
If they don't run to the fuse box and they just run to a little transmitter somewhere inside the overhead console, it might be a little more difficult.
You would have to run a brand new wire, and that might be a pain.
Ooh, RamTech, I didn't even think of that.
Nevermind all that lol
"If it's smaller than a 5-cyclinder, it's just a glorified motorcycle engine."
Last edited by dodgeguy; 02-11-2011 at 07:04 PM. Reason: RamTech is smarter than I am haha
Old 02-11-2011, 05:37 PM
Resident Technician
Rep:1915
Problem #1 - the buttons are momentary push switches, not on-off switches that you'd need to keep a relay energized.
Old 02-11-2011, 07:17 PM
Rep:404
[[IMG]
[IMG][/QUOTE]
Yeah I thought of that, even bought a center peice with switches from another member but have since read you cannot order or add any swithces to that panel those switches are programed to the comp somehow. I have yet to take it apart to explore this farther though. anyone who know differantly please chime in.
Old 02-11-2011, 10:19 PM
Resident Technician
Rep:1915
The switches themselves aren't programmed but are in a LIN bus that goes to the cluster where the commands are sent to the TIPMCGW or other modules where they are executed.
Old 02-12-2011, 01:41 AM
Rep:404
sorry Randy thats just a little over my head. is there any way i can take some of the switches from the piece i bought and add them to the blank spots by my seat heat switches and wire them to a power souce and use to control accessories?
Old 05-19-2011, 10:46 PM
KLuna's Avatar
KLuna KLuna is offline
Vehicle: 2010 Dodge Ram 1500 Hemi
Trim Level: SLT Big Horn
Rep:22
KLuna is on a distinguished road
Amazon.com has a 12v remote switch, just program the signal into the garage door button, wire up the remote switch under the hood, and there you go. Just search "12v remote switch" they are like $25 shipped.
Overhead Console Wiring Vikefan4eva Electrical 3 02-13-2011 06:14 AM
Question about behind the grille lights 348 red ram 2009 Dodge Ram Forum 5 02-11-2010 05:31 AM
Overhead console removal. bones64 LD RAM - General Discussion 11 02-08-2010 05:46 PM
A question about in-grille lights Marcelo Custom Dodge Ram Interior and Exterior Lighting 20 01-30-2010 01:15 PM
Help! Looking for a stock overhead console for 2001 1500 quad cab BigE450 Newbie Checkin! 11 01-24-2010 03:18 PM
