revers lights problem - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Electrical
Old 02-10-2011, 09:20 PM
bjordan1109's Avatar
bjordan1109 bjordan1109 is offline
Vehicle: 2001 Dodge Ram Ext. Cab
bjordan1109 is on a distinguished road
Default revers lights problem
truck just failed MD state inspection because when placed in reverse, the reverse lights dont stay on all the time. when i tap on the shifter, without pulling it in, towards the park position they come on though so i know they are not shorted out completly...
any fix sugestions?
Old 02-10-2011, 10:43 PM
Resident Technician
Rep:1915
Sounds like you may have a sticking backup light switch or a slightly misadjusted shift linkage.
Old 03-28-2011, 11:42 AM
still have this problem, havent really messed with it much but i need to get this truck through inspection so i can renew my tags.....
my money is on the shift linkage, that best describes the problem i am having because when i push the comlum shift towards the park position the lights will activate, so it seems like it just needs and "alingment" so to speak..
so, can any one tell me how to make the adjustments i need to make.. thanks
Old 03-28-2011, 12:11 PM
Resident Technician
Rep:1915
LINKAGE ADJUSTMENT
Check condition of the shift linkage. Do not attempt adjustment if any component is loose, worn, or bent. Replace any suspect components.
Replace the grommet securing the shift rod or torque rod in place if either rod was removed from the grommet. Remove the old grommet as necessary and use suitable pliers to install the new grommet.
  1. Shift transmission into PARK.
  2. Raise and support vehicle.
  3. Loosen lock bolt in front shift rod adjusting swivel. Ensure that the shift rod slides freely in the swivel. Lube rod and swivel as necessary.
  4. Move transmission shift lever fully rearward to the Park detent.
  5. Center adjusting swivel on shift rod.
  6. Tighten swivel lock bolt to 10 Nm (90 in. lbs.).
  7. Lower vehicle and verify proper adjustment.
1 - FRONT SHIFT ROD
2 - TORQUE SHAFT ASSEMBLY
3 - TORQUE SHAFT ARM
4 - ADJUSTING SWIVEL
5 - LOCK BOLT
2003 ram 3500 trailer lights problem 2003duallyram Custom Dodge Ram Interior and Exterior Lighting 5 11-27-2010 11:10 AM
fuse for dash lights 15amp shorted num 35 i think problem started after towing traile edgar artecona Electrical 1 11-11-2010 12:05 PM
Tow lights problem JAM Electrical 3 08-14-2010 06:30 AM
another trailer lights problem scbachman Newbie Checkin! 3 06-09-2009 07:55 PM
Problem with running/brake lights. BigB Electrical 3 12-27-2008 11:08 AM
