Old 02-10-2011, 10:48 PM
Torq89 Torq89 is offline
Vehicle: 2005 Ram 2500
Color: Grey
Rep:87
Torq89 will become famous soon enough
Default What do you guys think......
About one inch wheel spacers for my truck? I would like my wheels to stick out a little more but don't want to spend $1k on new rims. I've heard that wheel spacers will chew up your wheel bearings though so I'm kinda undecided. I've also thought about 1/4 in spacers but I don't think they would stick out as much as I would like. Any pics would be appreciated also, thanks.
Old 02-10-2011, 10:50 PM
jcasey10's Avatar
jcasey10 jcasey10 is offline
Vehicle: 2002 Dodge Ram
Trim Level: SLT Quad Cab
Rep:869
I would say don't go for it. Sounds like a bad idea and good way to screw something up.
Old 02-10-2011, 10:52 PM
Rep:1625
From what I've read on here, 1/2" spacers are about the max you should ever go.
Old 02-10-2011, 11:28 PM
SslagleZ28's Avatar
SslagleZ28 SslagleZ28 is offline
Rep:158
SslagleZ28 has a spectacular aura aboutSslagleZ28 has a spectacular aura about
This is correct, remember that the spacer takes away from thread length, so your jug nuts wont have as much to bite onto. Also you put more stress on the bolts when moving a wheel that far away from the hub. I really wouldnt even go the 1/2i either but its been done.
Backlash
Semper FI
Old 02-11-2011, 12:24 AM
Color: Grey
Rep:87
Even ones like these http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWAX%3AIT
Old 02-11-2011, 04:03 PM
ramrat's Avatar
ramrat ramrat is offline
Vehicle: 2006 Dodge Ram SLT 4X4
Trim Level: SLT 4X4
ramrat is on a distinguished road
I had a Nissan Frontier with 1.5 inch wheel spacers on it with 33" BFG's and a 3" lift. Sounds like I might have been at risk all along huh?
I never had any issues with the spacers (rubbing etc..., could the difference in truck weight have anything to do with it?
Also, my old Nissan never rubbed even while offroading. With the suggested 1/4" wheel spacers that most Ram owners are going with for clearance, do they rub while doing some 4x4ing?
Sorry for the multi questioning and hopefully answers to these questions will help you decide as well Torq89.
06' Red SLT Quad Cab 4x4. Bilstein 5100 2" level. .
Old 02-11-2011, 10:40 PM
ScatPak07's Avatar
Rep:970
The thing is you are looking at a wheel adapter. I think that is a little better then a spacer since you are keeping the length of the stock bolts. they are slightly different. Usually the adapters are used to change the bolt pattern, but in this case not.
I really am not sure about the safety of using spacers. It is such a contriversal product that I am not sure which side is true. I think keepign it to 1/4" or even 1/2" is the safest bet. You are still putting the stress on the bearing either way you go. Just hanging the wheel+tire out so much does have soem strain. Especially with a truck and some big heavy tires.
Old 02-11-2011, 11:00 PM
Color: Grey
Rep:87
Thanks for the help guys. I probably won't buy the adapters/spacers until spring so I have some time to sit on it.
Old 02-12-2011, 12:48 AM
platinuminjected's Avatar
Vehicle: 2009 dodge ram 1500
Rep:713
i would prolly go with a 1/2 as well
Old 02-12-2011, 02:23 AM
PorkChop's Avatar
PorkChop PorkChop is offline
Vehicle: 2009 ram 1500
Trim Level: sport
Color: brillian black
Rep:75
PorkChop will become famous soon enough
1 inch seem WAY too much, i would never do more than 1/4"
DODGE the father RAM the daughter!
What do you guys think about these rims? thatreddodge Dodge Ram Wheels And Tires 14 12-16-2010 03:19 PM
what do you guys think? HEMI time? RamItAll Dodge Ram General Discussion 24 12-01-2010 02:49 PM
What do you guys think of this lifting kit.. Bigunz Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 6 10-09-2010 04:48 PM
Need Some Help Guys! Truck won't start :-( Chet Stedman 5.2L V8 Specific Topics 6 10-01-2010 10:09 AM
Looking for AZ guys and gals aingrychair South West 35 04-10-2010 02:14 PM
