Dodge Ram Decals
Old 02-11-2011, 12:32 AM
starquestbd22's Avatar
Trim Level: Sport quad cab
Rep:367
Default Questions about synthetic oil and PCV valve
I've been reading a lot about the potential for sludge problems with the 4.7L. I don't have any reason to believe my truck has any problems and the previous owner swears the oil was changed religiously. But I don't know him so we know what that's worth. Any thoughts on switching to synthetic? Some seem to recommend it and some not so much. My truck has 59,000 on it.
Also, how hard/expensive is replacing the PCV valve? I can change oil, plugs, belts, etc but that one is a first for me.
And while I'm at it, what's this I read about busting radiators? Is this common to any particular years?
Thanks ahead of time!!
Old 02-11-2011, 12:37 AM
RootBeer RootBeer is offline
Vehicle: 2014 Ram 1500
Color: RootBeer
Rep:1287
Going synthetic should not be an issue. Probably benefit the motor in the long run. But keep in mind you cannot switch back if after a few oil changes you decide its to expensive to keep up with.
Changing the PCV valve shouldn't be to hard. Go to your local parts store like Autozone or NAPA and they should have a computer they can bring up the location and probably procedures as well.
Radiators are radiators, they all can fail. If you radiator goes don't waste your money getting it replaced until you've had a radiator shop tell you to do so. You do need to completely flush the cooling system at least once a year and that includes changing the thermostat.
Brian:
Old 02-11-2011, 08:07 AM
HVACeR HVACeR is offline
Color: Mango Tango
Rep:113
HVACeR will become famous soon enoughHVACeR will become famous soon enough
I disagree with the once you go syn you can't/shouldn't go back to dino.
I think that it's an old tale that has continued to get propagated and has come to be somewhat of truth. I've never heard of anyone who personally has made the switch and had anything detrimental happen. It always seems to be one of those "My cousin's uncle's next door neighbors friend made the switch and the engine went kaboom"
I personally made the switch just as an extra level of protection, but as long as you stay with the recommended oil weight, I believe everything should be fine.
As always, your mileage may vary.
MODS: BellTech 2/4, Air Lift 1000 Air Bags, Mufflex DOD14M, Partial Debadge, Pin stripe removal, B Pillar blackout removal.
Old 02-11-2011, 08:28 AM
LEW LEW is offline
Vehicle: 2002 Ram 1500 Quadcab 4X4
LEW is on a distinguished road
Concerning syn oil, the directions are to use conventional oil for the first "couple" of changes. This will allow for normal engine break in. After that, you can use either syn or conventional, switching back and forth, without any problems. I have personally used syn then conventional and I have syn (I bought on sale) for the next change. 63k miles so far.
Old 02-27-2011, 11:38 AM
charlieb's Avatar
charlieb charlieb is offline
Vehicle: 2011 ram slt 1500
Rep:33
charlieb is on a distinguished road
yes i have used synthetic in wifes car periodically just to clean out possible sludge 1 time per year on average changing oil 3-4 times a year with penzoil conventional at other times run synthetic in all my trucks from time i buy to sell.never any problems or leaks at all i do understand the old timer mechanic who has seen vehicle come in with 200,000 miles on it built up with sludge change to synthetic and maybe a seal like in that situation ive heard from the horses mouth and believe that its a possibility in the most extreme situations because the synthetic really does clean out built up sludge in ur engine from poor quality oil and bad interval changes
