Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Body & Interior
Old 02-11-2011, 12:08 PM
adventurer's Avatar
adventurer adventurer is offline
Vehicle: 2010 Ram and 2006 Ram Hemi
Trim Level: 4x4 SLT and4X4 SPORT
Color: Silver , Flame Red
adventurer is on a distinguished road
Send a message via Skype™ to adventurer
Default Water leak please help
i have bought my 2006 hemi quad cab slt ram one month ago and till now am busy in this water leak issue from rear window and third break light and rear vents , i read all the threads about water leak and done everything like re sealing rear window and sealing the third break light and checking the rear vents and with all that the water still leaks ???? dont know how and from where , i didnt enjoy my new truck till now because am trying to fix this problem , am fed up with this and i like the truck i dont want to sell it , any ideas what to do ???
thanks in advance ,,,
2010- S&B CAI/87MM TB/HKS TB GW/OIL FILTER BREATHER/Y PIPE/PYPES VIOLATOR MUFFLER/HEMIFEVER TUNE.
06- MAGNAFLOW CAT-BACK/Y PIPE/TB SPACER/HKS-TB GW/MOPAR CAI/SUPERCHIPS/OIL BREATHER FILTER/JET 180 TSTAT/3.92 LSD
Old 02-11-2011, 12:21 PM
bamasport's Avatar
bamasport bamasport is offline
Vehicle: 2010 Dodge Ram 1500 Crew 4X4
Color: deep water blue pearl
Rep:186
bamasport has a spectacular aura aboutbamasport has a spectacular aura about
Have you checked the door seals? if you have checked all the rest, such as rear windows, 3rd brake light and rear vents, there isnt many other possibilites other than rear door seals and rear door window seals. what did you use to reseal the others?
3.92 rear axle, OEM 20" rims, 20% tint, Mopar wheel-to-wheel side steps, K&N drop-in air filter, LineX bedliner, OEM Tow hooks, Rampage Tailgate Light Bar, Borla Cat Back, 6" BDS lift, 35x12.50x20 Nitto trail grapplers, Custom painted interior, dodge slush mats
JON
Old 02-11-2011, 12:28 PM
adventurer's Avatar
Door seals are ok no leak , i used black silicon for sealing but still little bit of leaking from rear window (i re sealed it 2 times ) and some leak from the slide window but i dont know from where is the big leak
Old 02-11-2011, 12:32 PM
bamasport's Avatar
Rep:186
hmmmm, i'm not sure then. i would say remove all the seals around the rear windows and sliding windows and strip all silicone off gasket and reseal once more and give it the allotted amount of time to dry.
JON
Old 02-11-2011, 12:37 PM
adventurer's Avatar
thats what i ll do next week , it really gave me headache , thanks and i will inform you the result later
Old 02-11-2011, 12:38 PM
bamasport's Avatar
Rep:186
hope it works out for you! and keep us informed. there may be others who have some more input here also, so keep your eye on the forumz.
JON
Old 02-11-2011, 12:53 PM
adventurer's Avatar
[QUOTE=bamasport;440386]hope it works out for you! and keep us informed. there may be others who have some more input here also, so keep your eye on the forumz.[/QUOT
Thanks , i will do that
Old 02-11-2011, 01:38 PM
uktitus uktitus is offline
Vehicle: 2009 dodge Ram 1500 4x4
Trim Level: Laramie crew cab
Color: Grey
Rep:41
uktitus is on a distinguished road
May I suggest that you remove the seals one at a time and reseal starting with the highest one I know this is time consuming but you need to eliminate each possibility individually. Also we might have a better Idea of what is happening if you say what is actually is wet and where. As a builder I can say that blind caulking and caulking every thing can cause it's own problems which become harder to solve.
Old 02-11-2011, 02:06 PM
adventurer's Avatar
the most wet things is behind the drivers side rear seat , and it leaks also from the upper right side of the rear window ( behind rear passenger ) and from the middle upper side of the rear window and also there is water in the rail of the slide window
Old 02-11-2011, 03:55 PM
Color: Grey
Rep:41
Have you tried sealing and covering the back window completely with plastic and duct tape,
just make sure that the plastic and tape are tight and when it rains look to see if water has got behind the cover. All you can do is try to isolate each external likely problem point individually.
Water Leak 09 CrewCab Body & Interior 22 06-21-2011 10:26 PM
Water leak?!? cody0789 4.7L PowerTech V8 Specific Topics 3 09-11-2010 04:12 PM
Water leak Buckster 2010 Dodge Ram Forum 5 06-09-2010 01:33 PM
Water pump leak? rustyolred Custom Dodge Ram Performance Mods - Engine - 5.9 Liter V8 30 03-31-2010 12:00 PM
Water on the moon?! 98sst Off Topic Discussion 13 11-15-2009 07:50 AM
