Water leak please help - Page 2 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Body & Interior
Old 02-11-2011, 04:01 PM
adventurer's Avatar
adventurer adventurer is offline
Vehicle: 2010 Ram and 2006 Ram Hemi
Trim Level: 4x4 SLT and4X4 SPORT
Color: Silver , Flame Red
adventurer is on a distinguished road
Originally Posted by uktitus View Post
Have you tried sealing and covering the back window completely with plastic and duct tape,
just make sure that the plastic and tape are tight and when it rains look to see if water has got behind the cover. All you can do is try to isolate each external likely problem point individually.
thanks, i ll do that before i re sealed everything again
2010 CREW CAB 4x4 - S&B CAI/87MM TB/TB GW/JET 180/OIL BREATHER FILTER/MAGNAFLOW MUFFLER DUAL IN - SINGLE OUT/CATS DELETED/HEMIFEVER TUNE/ROUGH COUNTRY LEVELING KIT/(LT285/70/17) COOPER STT
Old 02-11-2011, 04:04 PM
Rep:2929
here are some others having the same problem & how it was resolved
you may even see your own question
http://www.google.com/#sclient=psy&h...15e03a94d415c7
Old 02-25-2011, 09:15 AM
dodgeowner1 dodgeowner1 is offline
Vehicle: 2006 Dodge Ram
dodgeowner1 is on a distinguished road
Originally Posted by adventurer View Post
the most wet things is behind the drivers side rear seat , and it leaks also from the upper right side of the rear window ( behind rear passenger ) and from the middle upper side of the rear window and also there is water in the rail of the slide window
I had this problem and took it to the dealer many times to figure it out.. the only thing that seems to have worked was when they cleaned out the water drainage tracks. There are tracks all along the truck where water is supposed to run off which is why sealing spots doesn't really work. the problem is happening again because im guessing it has gotten clogged again.
Old 08-29-2014, 07:55 PM
my hemi my hemi is offline
Vehicle: 2013 ram sport regular cab
Trim Level: sport
my hemi is on a distinguished road
Default hi
[QUOTE=bamasport;440367]Have you checked the door seals? if you have checked all the rest, such as rear windows, 3rd brake light and rear vents, there isnt many other possibilites other than rear door seals and rear door window seals. what did you use to reseal the others? my truck take water from those 2 rear vent they are supose to get new vent i will let you know if it take water again
Water Leak 09 CrewCab Body & Interior 22 06-21-2011 09:26 PM
Water leak?!? cody0789 4.7L PowerTech V8 Specific Topics 3 09-11-2010 03:12 PM
Water leak Buckster 2010 Dodge Ram Forum 5 06-09-2010 12:33 PM
Water pump leak? rustyolred Custom Dodge Ram Performance Mods - Engine - 5.9 Liter V8 30 03-31-2010 11:00 AM
Water on the moon?! 98sst Off Topic Discussion 13 11-15-2009 07:50 AM
