Old 02-11-2011, 04:23 PM
16again's Avatar
16again 16again is offline
Trim Level: SLT Big Horn Edition
Rep:58
16again will become famous soon enough
Default First Mod - Brake Controller
Installed the factory brake controller. Installed in only a few minutes. Powered right up without issue. Looks sooo MUCH better than the prodigy unit I had screwed to the bottom of the dash on my 2007 Ram.
The exclamation point is because no trailer was hooked up.
Old 02-11-2011, 04:27 PM
Rep:2642
is it the stock controller?
part numbers ?
any issues ?
Old 02-11-2011, 04:44 PM
16again's Avatar
Rep:58
part numbers ?
any issues ?
Yes it is. Controller Part #56029431AG
BLACK bezel Part #1EB13XDVAA
On my 2011 it's plug and play. EVIC has not been flashed yet. No issue with install only takes a few minutes.
Old 02-11-2011, 07:00 PM
pjs1660's Avatar
pjs1660 pjs1660 is offline
Vehicle: 2011 ram 1500 outdoorsman
Trim Level: slt outdoorsman
Color: green
Rep:137
pjs1660 will become famous soon enoughpjs1660 will become famous soon enough
got mine today ! it was shipped from fla but they neglected to include some fla weather. waiting for a warm up here so ican do the install
Old 02-11-2011, 07:43 PM
cudase's Avatar
cudase cudase is offline
Vehicle: 2011 Dodge Ram
Trim Level: Sport Crew Cab
Color: Mineral Gray Metallic
Rep:53
cudase will become famous soon enough
When you say plug and play, will it work as is with the controls on the unit or does the EVIC have to be flashed for it to work.
If not, what advantage does having the EVIC flashed provide?
Old 02-11-2011, 07:53 PM
RootBeer RootBeer is offline
Vehicle: 2014 Ram 1500
Color: RootBeer
Rep:1287
Nice mod. Thanks for the pics.
Brian:
Old 02-11-2011, 08:40 PM
16again's Avatar
Rep:58
Plug it into the connectors under the dash and it's 100% operational. All the EVIC programming does is allow you to see it on the dash. The EVIC programming is not needed to use this device.
Think of it as adding an aftermarket unit, no programming needed. This is the same thing.
Old 02-11-2011, 08:44 PM
16again's Avatar
Rep:58
I bet we bought it from the same place. Mine came from TAMPA in 1 day.
Packaging left MUCH to be desired as the unit was bouncing around in a big empty box. I called and told them I was not amused and if I had any thought it would not work it was coming back, electronic device or not. They apologized and said no problem. Luckily it's fine.
Install took just over 10 minutes, I was taking my time. Super easy.
Old 02-11-2011, 08:49 PM
AddictedSC AddictedSC is offline
Vehicle: 2011 Ram 1500 Laramie Crew Cab
Trim Level: Laramie 4x4
Rep:13
AddictedSC is on a distinguished road
How much was it? Website? Thanks.
Old 02-11-2011, 08:55 PM
16again's Avatar
Rep:58
$112.00 with bezel shipped. http://www.mopar-wholesale.com
2010 Ram Factory Trailer Brake Controller Install Netman66 Dodge Ram Knowledge Base 334 04-17-2014 01:51 PM
OEM brake controller flash Jgroes 5.7L (345 cu in) HEMI V8 Specific Topics 1 10-14-2010 11:48 AM
Adding a electric brake controller dave k Electrical 3 08-06-2010 10:36 AM
Installing Tekonsha Brake Controller - No Power mullinon 2010 Dodge Ram Forum 6 07-15-2010 01:04 PM
led third brake light/brake controller pa03hemi Custom Dodge Ram Interior and Exterior Lighting 3 05-20-2010 03:26 PM
