Place your Ad Here!
Old 02-11-2011, 10:33 PM
cudase's Avatar
cudase cudase is offline
Vehicle: 2011 Dodge Ram
Trim Level: Sport Crew Cab
Color: Mineral Gray Metallic
Rep:53
cudase will become famous soon enough
Originally Posted by 16again View Post
Plug it into the connectors under the dash and it's 100% operational. All the EVIC programming does is allow you to see it on the dash. The EVIC programming is not needed to use this device.
Think of it as adding an aftermarket unit, no programming needed. This is the same thing.
Thanks,
I was told by the dealership that if the truck didn't have it from the factory it would not work. I will order one tomorrow morning.
Old 02-11-2011, 10:37 PM
16again's Avatar
16again 16again is offline
Trim Level: SLT Big Horn Edition
Rep:58
16again will become famous soon enough
Originally Posted by cudase View Post
Thanks,
Dealer told me the same thing. Bunch of folks here were told the same thing as well. They all have working brake controllers that they purchased from RAM and installed themselves.
Old 02-11-2011, 11:29 PM
cudase's Avatar
Rep:53
I will be stopping in at the dealership with the Part Numbers you provided and see what the price is. Part of my purchase agreement was parts and accessories at cost so hopefully I can get a decent deal. If not, I will order from the link provided earlier.
Thanks
Old 02-12-2011, 10:47 AM
pjs1660's Avatar
pjs1660 pjs1660 is offline
Vehicle: 2011 ram 1500 outdoorsman
Trim Level: slt outdoorsman
Color: green
Rep:137
pjs1660 will become famous soon enoughpjs1660 will become famous soon enough
I bet we bought it from the same place. Mine came from TAMPA in 1 day.
Packaging left MUCH to be desired as the unit was bouncing around in a big empty box. I called and told them I was not amused and if I had any thought it would not work it was coming back, electronic device or not. They apologized and said no problem. Luckily it's fine.
Install took just over 10 minutes, I was taking my time. Super easy.
yep same issue here same place too
Old 02-12-2011, 12:48 PM
pjs1660's Avatar
Color: green
Rep:137
it got up to 30 degrees so i just installed mine it'll be a while until i can dig out the camper for a hook up and truly test it out
Old 02-12-2011, 01:11 PM
16again's Avatar
Rep:58
30 degrees? Must be a heat wave, damned global warming. One of the easier faster mods to perform.
Did it power up like my picture? If so your good to go.
Old 02-23-2011, 10:19 PM
RedDodge's Avatar
RedDodge RedDodge is offline
Vehicle: 2014 Dodge Ram
Color: Granite
Rep:25
RedDodge is on a distinguished road
Under the hood there are 2 fuses marked "M2" and "M4" which is a 15 and 10amp fuse and noted as "trailer"..did you have to put a fuse in these spot?
I've gotten that all over that it won't work...spoke with a dealer that said a "kit" was due out in march? Has anyone installed this and not have it work?
Steve
Steve
www.monteman.com
Mods: Tinted front windows, UnderCover tonneau bed cover, step rails, bed mat, cabin air filter, 4 corner mud flaps, slush mats, drop in K&N filter.
Old 02-23-2011, 10:40 PM
pjs1660's Avatar
Color: green
Rep:137
i didn't put any fuse in and mine powered up and shows the display haven't been able to hook up yet to make sure it works the trailer brakes and haven't been to dealer for flash yet
Old 02-24-2011, 02:10 AM
Rep:2910
I don't think the dealer will or can do a flash for it
something about the manufacturer has to add it some how to your vehicle build specs & they won't or can't do it, that has to be done for the flash to work
damn modern electronics
Old 02-24-2011, 06:57 AM
UltraFlame's Avatar
Vehicle: 2007 Dodge Ram Quad
Rep:840
That looks great where it mounts. Good job.
Installing Tekonsha Brake Controller - No Power mullinon 2010 Dodge Ram Forum 7 02-18-2017 09:18 PM
2010 Ram Factory Trailer Brake Controller Install Netman66 Dodge Ram Knowledge Base 340 02-03-2017 12:10 PM
OEM brake controller flash Jgroes 5.7L (345 cu in) HEMI V8 Specific Topics 1 10-14-2010 11:48 AM
Adding a electric brake controller dave k Electrical 3 08-06-2010 10:36 AM
led third brake light/brake controller pa03hemi Custom Dodge Ram Interior and Exterior Lighting 3 05-20-2010 03:26 PM
