R/T Tow Rating - Page 2 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 06-23-2011, 11:31 AM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1388
h20loo, so you compared the RT torque converter number with a regular truck and they were the same? I also believed it was the torque converter, as I watched a whole video on the RT and how it had the loose converter... I'd love to know if it is a different converter or not...
Sean
Old 06-23-2011, 11:42 AM
LeKy411's Avatar
LeKy411 LeKy411 is offline
Vehicle: 2011 Ram 1500
Color: Blue
Rep:100
LeKy411 will become famous soon enoughLeKy411 will become famous soon enough
Originally Posted by roll View Post
Towing; Axle Ratio !!!!!! tire size ! With Ford,Chevey,Ram all have low and high tow rating with "Axle Ratio"!
Well the bastard Child of the Laramie and the R/T, also known as the sport with 3.55's is only rated a 7,600lbs with (20inch wheels) and a weight distribution hitch. Those 9100lbs rating is only if you have 17inch wheels.
Old 06-23-2011, 12:28 PM
Rep:2964
engine size, transmission, rear axle ratio, & rim size are not the only things that are involved in the calculation
if you had leaf springs instead of coil springs, you could tow more
after all, what is the difference between the 1500 & 2500 series ?
here is a tow chart
click first on VEHICLE ( the weight shows when you click each vehicle,
then click LOAD WEIGHT, use the slider for heavier trailers
http://www.dodge.com/towing/D/vehicle_to_weight.jsp
to see what difference wheel size makes, look at this website
http://onlinetowguide.com/guidelines...apacities.html
Octane Rating (good info) Jay Fuel System 21 06-08-2011 01:02 AM
Tow rating with a gooseneck hitch jayingf Towing 9 01-12-2011 11:20 AM
Axle manufacturers weight rating? WesGPS LD RAM - General Discussion 0 10-04-2010 02:48 PM
Help needed for axle rating question please. WesGPS Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 2 09-23-2010 02:01 PM
Octane Rating (good info) Jay LD RAM - General Discussion 3 03-27-2009 08:30 AM
