tonneaucovered.com
Old 02-12-2011, 04:01 PM
dirty dodge dirty dodge is offline
dirty dodge is on a distinguished road
Default front end rebuild question
can someone tell me what all the joints are in the front end?i know i need ball joints upper and lower. i also know i need outer tie rod ends. but that is the joint called thats in the cenyer of the tie rod that goes up to the gear box? what other joints can/should be replaced. sorry for the dumb question and thanks in advance.. btw the truck is a 98 2500 4x4 v10
Old 02-12-2011, 04:05 PM
Resident Technician
Rep:1911
The rod is called a drag link. You might also need a track bar - that's the one that goes from the frame to the axle.
front license plate? Freightrain Body & Interior 15 03-21-2011 06:52 AM
Left front caliper dragging?? yancyk Suspension 9 03-14-2011 10:51 AM
Charlie again ! Re prev post front end howl charlie Cummins Diesel Specific Topics 2 01-20-2010 09:26 PM
the front end or back end? that is the question! zacotaco Custom Dodge Ram Exterior Modifications - Body Mods - Body Kits 9 12-27-2008 05:12 PM
