Old 02-12-2011, 04:01 PM
kozzy kozzy is offline
Vehicle: 2014 Ram 2500 Outdoorsman
Trim Level: Outdoorsman
kozzy is on a distinguished road
Default 2011 Dash Speaker Upgrade
ok, along with upgrading my whole stock system , i want to upgrade my dash speakers. First, anyone have any pics on how to ge tto them,:"? Do the grills just pop off? Any help on that would be great.
Next question, I will be adding a 4 channel JL audio amp, which will drive the front and rear door speakers. I will be running all new wire, and essential leaving all the factory wiring intact, but not used. For the dash speakers I was thinking about running new wire from them, to the front outputs directly from the head unit.
Will that work? and will the fader still work, if those are hooked to the HU front channel and I have front AMP channel hooked up?
Thanks again
Old 02-12-2011, 11:14 PM
dodgeman70592's Avatar
Vehicle: 2008 Dodge Ram
Trim Level: Custom
Rep:1648
You are replacing the headunit also? If so, then yeah, you can run the das off of the front channels of the headunit, and use the amp for the 4 doors.
Old 02-13-2011, 01:03 AM
yes, head unit is being replaced also.
Thanks for the info dodgeman, would you happen to know, do the grilles for the dash speakers just pop off to gain access to the speakers themselves? I have some JL c350 i am going to replace them with.
thanks again
Old 02-13-2011, 01:13 AM
Trim Level: Custom
Rep:1648
Yes, the grills do just pop off on the 4th gen Rams
Old 02-13-2011, 02:52 PM
great..thanks for the info..
Old 03-26-2011, 02:44 PM
Krpto1973's Avatar
Krpto1973 Krpto1973 is offline
Vehicle: 2011 Dodge Ram 2500 4x4
Trim Level: Power Wagon
Color: Blue
Rep:71
Krpto1973 will become famous soon enough
Hey Kozzy, Can I ask how this upgrade went. I ahave already replaced the head unit and I am going to be replaceing everythign else with new speakers and a amp. I see nothing in my 2011 that looks like dash speakers. I only see openings for defroster type spots. Are the speakers "hidden" under the dash without grill openings.
Plus, if I use the new amp, I would assume I would be turning off the internal amp for the head unit. Which means the dask speakers (if they are actually there) could not be run off the normal outputs.
Now that I think about it, when I installed my head unit 3 weeks ago, there were no wires for dash speakers, only L/R for front and rear. If the dash speakers exist, are they powered off the front door speakers or something.
Anyone have any ideas about all that. I would really appreciate any input. These "dash" speakers are really throwing me off.
-2011 Dodge Ram 2500 4x4 Power Wagon
-2006 Suzki GSX-R 750, 2004 Triton Tr-19x
Old 03-27-2011, 01:29 AM
RAMTX's Avatar
RAMTX RAMTX is offline
Vehicle: 2012 Dodge Ram Crew Cab 4X4
Trim Level: Lone Star
Color: Bright Silver Metalic
Rep:110
RAMTX will become famous soon enoughRAMTX will become famous soon enough
On my installation I ran 2 new wires from the dash speakers to the front output wires of the head unit, and used my Alpine PDX-5 to power all 4 doors speakers and a 10' sub. Everything worked fine. The grills inserts just pop out I used a flat head screw drive to do it but be careful not to damage it. Good Luck.
__________________________________________________ ___________________
__________________________________________________ _____________________ K&N drop in Air Filter - Tonno Pro Tri-Fold Bed Cover
Old 03-27-2011, 11:19 AM
Krpto1973's Avatar
Color: Blue
Rep:71
Hey, thanks for the info and the pictures. I thought those slots were just heater vents or something. Thanks again!
Now I know what to do!
Old 03-27-2011, 11:28 AM
Krpto1973's Avatar
Color: Blue
Rep:71
RAMTX, I did still have one question. I know you said you used the 2 front output wires for your dash speakers, but any idea how they normally recieve their signal, if you have not changed things from stock?
Are the dash speakers normally slaved of the front speakers anyway, because I did not have any front dash speaker leads in the normal truck wiring harness (at least I did not notice them), and I assume you didn't have them either.
Old 03-28-2011, 01:09 AM
RAMTX's Avatar
Rep:110
I think they are slaved to the front speakers. I don't have a good wire diagram to look but when I looked on the back of my main radio connector i just saw the wires for the front and the back speakers.
those are all the color for the wires, if you need some guidance.
gray with light green stripe (RH dash speaker +)
gray with dark green stripe (RH dash speaker -)
gray with yellow stripe (LH dash speaker +)
gray with no stripe (LH dash speaker -)
gray with purple stripe (LH front door -)
gray with yellow stripe (LH front door +)
green with purple stripe (RH front door -)
green with yellow stripe (RH front door +)
2010 Dodge Ram Alpine RER stereo system upgrade / wiring harness diagrams chadzilla500 Custom Dodge Ram Interior Modifications - Custom Audio / Video 49 04-02-2013 01:03 AM
2011 Dodge Ram Quad Cab Radio Upgrade Assistance kozzy Custom Dodge Ram Interior Modifications - Custom Audio / Video 11 07-18-2011 04:23 PM
1994 CTD Dash Replacement johnny0874 Body & Interior 15 04-09-2011 11:22 PM
Replacing all doors and dash speaker tn6478 Custom Dodge Ram Interior Modifications - Custom Audio / Video 5 10-04-2010 01:34 PM
Speaker upgrade Tomhartzelt 2009 Dodge Ram Forum 5 01-26-2010 11:46 PM
