Old 02-12-2011, 09:16 PM
bgerard's Avatar
bgerard bgerard is offline
Trim Level: Big Horn 4x4 Crew
Color: Austin Tan Pearl
Rep:28
bgerard is on a distinguished road
Default Towing Tutorial
Being new to a truck that will tow most anything out of a ditch, and wanting to be ready to be play the good Samaritan (being a minister and all) I'd like a tutorial on what I need to be able to help others out of a bind.
I've got a tow hitch in the back and hooks in the front. What do I need and how do I go about this task?
Old 02-12-2011, 09:20 PM
RootBeer RootBeer is offline
Vehicle: 2014 Ram 1500
Color: RootBeer
Rep:1287
1. Good cable or tow strap with hooks on it.
2. NEVER tow in reverse. The hooks on the front of your truck are to pull you out.
3. Use the lowest gear possible. 4Low is good for this. Maximum power/torque with little speed. Read the manual on how to operate your 4wd.
4. Once the person is out of the ditch or whatever, stop. If you need to pull them after they are out put it in 4Hi if you are on dirt/snow/ice, etc. If you are on good pavement use 2WD. 4WD is not to be used on dry pavement.
Brian:
Old 02-12-2011, 09:51 PM
cudase's Avatar
cudase cudase is offline
Vehicle: 2011 Dodge Ram
Trim Level: Sport Crew Cab
Color: Mineral Gray Metallic
Rep:53
cudase will become famous soon enough
IMHO leave the vehicle in the ditch and let an insured wrecker service handle the removal. If you want to play good samaritan, check to make sure they are okay, offer to call someone for them and give them a climate controlled place to sit while they wait for the wrecker or a ride home. You will be wishing you didn't pull someone out when you are sitting in a court room because you damaged their bumper when you pulled them out.
Old 02-12-2011, 10:09 PM
Color: RootBeer
Rep:1287
Excellent advice. Seems I have to rep a bunch of others before I can rep you again.
Brian:
Old 02-12-2011, 11:24 PM
Crash's Avatar
Crash Crash is offline
Color: Deep water blue
Rep:401
And if you decide not to follow this advice at least hand the stuck person the end of the strap that is being conected the their vehicle to hook up to their own vehicle. and warn them that you will not be responsible if what they hook up to comes off when you pull on it.
Old 02-13-2011, 12:15 AM
Ram15002ndgen's Avatar
Ram15002ndgen Ram15002ndgen is offline
Vehicle: 97 Ram 1500
Trim Level: Laramie SLT
Rep:55
Ram15002ndgen will become famous soon enough
I have to agree with Cudase. Being a Minister you can warm their body and their soul since I'm sure you have the good book with you at all times. Let the Tow truck lift the vehicle while you lift the soul. At least I have never heard of anyone being sued for lifting the other persons soul.
www.beatcraigslist.com - for posting dangers & secrets
Old 02-13-2011, 01:26 AM
Rep:2657
I also have to agree with the above texts
if your fairly close to a town, call the wrecker for them, they have or should carry $1,000,000 commercial insurance
if your out a ways from town, use a tow strap, not a chain, connect it up to your vehicle only & hand the other end to the person in distress, explaining what may happen to both of your vehicles IF ...
now if its a person of the opposite gender, you have to play it by ear, never connect to a newer vehicle axle & beware of the possibilities, like broken parts & peoples attitudes
Old 02-13-2011, 01:33 AM
I also agree with Cudase. No need to open yourself up to a lawsuit.
Let the pros do the job.
Old 02-13-2011, 02:06 AM
foolioGrimz foolioGrimz is offline
Vehicle: 1999 dodge ram
Trim Level: 1500
Color: Green
Rep:56
foolioGrimz will become famous soon enough
ive been pulled out plenty of times at the beach. we always paid in beer.
mods-Ranch hand Brush guard, superchip tuner, 75 gal transfer tank, 4.10 gears with detroit locker, 305/70-16 BFG mudders, 2" lift, Chrome Edelbrock carb filter with throttle body mod, and a short glasspack.
Old 02-13-2011, 02:29 AM
PorkChop's Avatar
PorkChop PorkChop is offline
Vehicle: 2009 ram 1500
Trim Level: sport
Color: brillian black
Rep:75
PorkChop will become famous soon enough
never use chains, they break too easy and when they do they cause damage, i dont like your standard tow slings...there meant for you average baby cars, i have a few crane slings that i got at "titan supply" but can be found at any rigging supply company, it have a 5:1 safety ratio and a 26000lb lifting capacity and when you use it in a horizontal scenario it is 5 times the lifting capacity so 130000lb capacity, and if that still isnt enough for ya, if you basket it it will double again giving me a 260000lb capacity. the strap is 25' long and 3" wide, and totaly overkill i know but it was on the discount rack for $30. for the average person there are nylon slings that have an 8800lb capacity, there lightweight and superstrong (44000lb pull capacity before safety ratio of 5:1)and fit in the truck noproblem. plus theyre only about 25-20$
DODGE the father RAM the daughter!
Towing Limits fewtree Towing 25 09-29-2011 09:18 PM
Auto-Dimming Towing Mirrors on Laramie tyros 2010 Dodge Ram Forum 12 02-18-2011 08:17 AM
Towing with an off-road Ram Optimistic Paranoid Towing 6 11-26-2010 12:59 PM
Your opinion on towing... Tootall Dodge Ram General Discussion 7 09-04-2010 06:27 PM
Another Towing Question ram06bighorn Towing 10 07-01-2010 05:03 PM
