Old 02-13-2011, 10:32 AM
str8hemi's Avatar
str8hemi str8hemi is offline
Vehicle: 2005 Dodge Ram
Rep:49
str8hemi is on a distinguished road
Default Bought new HID bulbs but have problems
So I originally had 8k HID kit on my 05 dodge ram, which at first had the flicking issue. I bought a can bus canceller and it fixed the issue. But now I bought some 6k hid bulbs and you can notice a bouncing like issue with them. If you are looking right at the headlights and fog lights you can't notice the bouncing but if you are inside the truck and you shine the headlights and fogs to a wall you can notice them bouncing a little(sort of like a small flicker). Is this normal for the HIDs?
Old 02-13-2011, 12:28 PM
Chance05Ram's Avatar
Chance05Ram Chance05Ram is offline
Vehicle: 2005 Dodge ram 1500
Chance05Ram is on a distinguished road
The bulb might be loosely installed?
like if you go over a bump or crack can you notice them move up and down rapidly?
Old 02-13-2011, 12:38 PM
str8hemi's Avatar
Rep:49
No, it's just while i'm in my driveway not moving. But the light bouncing that i'm trying to describe is like if i'm moving and the bulb is loosely installed. But it does it while just sitting still.
Old 02-13-2011, 12:48 PM
Do you have single beam or bi xenon? My bi xenon bulbs connect together after I put that plastic bulb lock down piece. If the bulb isn't twisted together tightly I noticed the bulb moved even with the truck sitting still.
Old 02-13-2011, 01:35 PM
str8hemi's Avatar
Rep:49
i have the bi xenon bulb. I'll double check all bulbs and make sure they are secured.
Old 02-13-2011, 03:09 PM
platinuminjected's Avatar
Vehicle: 2009 dodge ram 1500
Rep:713
ummm in motsure what to tell you bud do you have the compasator with this new kit and all the other things you had hooked up with the 8k?
Old 02-13-2011, 07:49 PM
str8hemi's Avatar
Rep:49
Yeah I have the exact same setup, all i did was change the bulbs out. I think they might be defective. I'm going to try to exchange them.
Old 02-13-2011, 09:00 PM
You will get a small "bounce" or flicker as the can bus system is always checking voltage across the circuit, causing a small momentary voltage drop.
Old 02-13-2011, 09:23 PM
str8hemi's Avatar
Rep:49
^So there is no way around that?
Old 09-28-2011, 03:39 PM
ggoat21's Avatar
ggoat21 ggoat21 is offline
Vehicle: 2007 dodge ram hemi
Trim Level: LARAMIE
Color: ELECTRIC BLUE
ggoat21 is on a distinguished road
Default dang hids
What did you do to get rid of the flickering issue?
interior lights in 98 ram 1500 lacamu Custom Dodge Ram Interior and Exterior Lighting 6 08-12-2011 03:43 PM
Bought a new truck a few months back and nothing but problems at first! heffs03mach1 2010 Dodge Ram Forum 8 02-03-2011 10:33 PM
Just bought a 2001 quad cab 5.2 PROBLEMS!!! DarkRam01 5.2L V8 Specific Topics 20 12-28-2010 02:22 PM
Bought truck yesterday and having shifting problems today! scubasteve6902 5.7L V8 Specific Topics 10 08-09-2010 12:41 PM
Bought an 01 Ram...problems with it and the dealer! townsley4 Dodge Ram Dealer Issues - VIN and Order Tracking - Dodge Ram MSRP & Pricing Discussion 14 03-14-2010 09:34 AM
