Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Body & Interior
ZDOG
Old 02-13-2011, 02:53 PM
StormTrippinFiVe9 StormTrippinFiVe9 is offline
Vehicle: 1999 Dodge Ram
Trim Level: Sport; Blue decals
Rep:17
StormTrippinFiVe9 is on a distinguished road
Send a message via AIM to StormTrippinFiVe9
Arrow Rear window leaks
Hey all,
Everytime a nice rain comes in my rear window starts to leak alittle around the top where the head liner and the top window meets. I'm almost positive that I am not the only one that has gone through this problem and was wondering if theres a good way of fixing this problem without spending a lot of money.
I was thinking it could possibly be a leak coming from a crappy gasket from the 3rd brake light or if the seal around the window is going bad or both. I've heard you can get silicone or something of that sort from a trip to Home Depot and that could fix that problem too.
Any suggestions from someone that has done this would help.
Thanks
Old 02-13-2011, 02:59 PM
Resident Technician
Rep:1911
Either one is possible. You need to locate the leak first by running water over the window seal and then the brake lamp. I wouldn't call the gaskets around the lights crappy but they can certainly dry rot in 12 years.
Old 02-18-2011, 10:10 AM
brewman brewman is offline
Vehicle: 1997 Dodge Ram 1500 4xr4
Color: Green
Rep:63
brewman will become famous soon enough
I had a similar problem, and after water testing found both the brake light and window were leaking.
Replaced the brake light gasket with a new gasket although you could just as easily use RTV/Silicon/etc. The downside of RTV/Silicon is it's a bigger hassle if you ever have to remove the brakelight, and it can dry out/crack over time just like the foam gasket.
My rear window was leaking around edges as well as the slide window weatherstripping. I was able to get a new solid window installed for $268 - don't ever use the sliding rear window and it's more weatherproof and secure this way.
Old 02-22-2011, 02:14 PM
Ripley9223's Avatar
Ripley9223 Ripley9223 is offline
Vehicle: 1999 Dodge Ram 2500HD
Ripley9223 is on a distinguished road
I had a similar problem with my 99 Ram. After only having the truck for a little over a week when the problem arose, I was a little freaked out.
Long story short, I opted to take the 3rd brakelight out, clean off all the old gasket material and purchased a silicone based RTV. re-installed the light and sealed the two joining surfaces. problem fixed. While I was there and had left over RTV, I also went around the gasket for the window itself. No more leaks. Hope this helped, sounds like you have the same problem that I experienced.
'99 2500HD Sport
New Rear window with defrost 05DodgeRam2500 Dodge Ram General Discussion 17 02-18-2016 02:39 PM
How do I disable the rear sliding window. persuazion Dodge Ram General Discussion 7 03-20-2015 11:13 AM
Flat Rear Window vs. Ability to Open RammD Dodge Ram General Discussion 14 08-04-2010 05:55 PM
Sliding rear window vs fixed window w/ defroster ronnchy Dodge Ram General Discussion 5 10-04-2009 10:28 PM
Rear window defroster red041500 2009 Dodge Ram Forum 5 09-24-2009 11:09 AM
