Old 02-13-2011, 04:46 PM
D.Rowe's Avatar
D.Rowe D.Rowe is offline
Vehicle: 2005 Dodge Ram 1500 Daytona
Trim Level: Daytona
Rep:121
D.Rowe will become famous soon enoughD.Rowe will become famous soon enough
Default Truck newbie..therefore truck tire newbie ???'s
So I'm in the market for 4 new ones for my 2005 Daytona. Stock tires are 275/60/20.
Can i put something wider with lower profile than the stock 275/60's?
If yes...what are some limitations on this rim size? I don't want to do anything stupid and I assume the installer will remind me if I deviate from stock size.
No off-road needs for me so still looking for a solid all season highway tire here.
Thanks,
Dave
Weather Tech mats, 12" Billet Antenna, Recon 60" LED bar, Spyder LED tailights, Map & Dome LED's, Pioneer AVH-P6300BT, Upgraded Tweeters in Dash, Cadence 8" Sub under Drivers Seat
Old 02-13-2011, 05:12 PM
D.Rowe's Avatar
Trim Level: Daytona
Rep:121
Default Options..
So I've narrowed my research down to these two..at least for now and would love to hear from owners of either tire...
General Grabber HTS All Season
http://www.tirerack.com/tires/tires....el=Grabber+HTS
and
Michelin LTX M/S2
http://www.tirerack.com/tires/tires....Model=LTX+M/S2
Price diff is about $250 in total so not concerned either way.
Old 02-13-2011, 05:22 PM
platinuminjected's Avatar
Vehicle: 2009 dodge ram 1500
Rep:713
im not the best with tires either but im sure there will be multiple ppl chime in on this for you
Old 02-13-2011, 05:25 PM
D.Rowe's Avatar
Trim Level: Daytona
Rep:121
Thanks..i look forward to it..and I am also open to other all season performers here as well.
Old 02-15-2011, 09:01 PM
ScatPak07's Avatar
Rep:970
Are those the only 2 tires that you found appealing? I ask since I think you can find much better ones. If you want to get a highway (A/T) tire then look at these ones. BF Goodrich A/T KO, Toyo Open Country, Nitto Durra & Terra Grappler, Cooper Zeons. Those are really good tires but they might be a little more expensive....since they are much better.
You can go wider then the stock width. I have 305/55/20 BF G A/T KOs on my truck and they only rub when at full lock under load. So really that would be either in a parking lot or doing a 3 point turn. I lived with it since I barely have the tires at full lock. Honestly they dont even do it all the time.
Old 02-16-2011, 09:37 PM
D.Rowe's Avatar
Trim Level: Daytona
Rep:121
Thus far yes..but I am open to your suggestions. Is there one tire in the list you provided that will be the best on the highway as far as comfort and noise but still give me what I need for the snow in CT?
Also..when you say your 305/55's rub..where exactly does this happen..just trying to visualize this....is it when you max out the wheel for a turn?
Dave
Newbie truck owner 130eagle Newbie Checkin! 12 09-30-2009 02:39 AM
Newbie, Truck running horrible wayfast1500 5.9L V8 Specific Topics 0 07-26-2009 10:51 PM
Yep, newbie with tire question nyg42best Newbie Checkin! 11 07-09-2009 01:37 AM
newbie with hho added to truck JKP Newbie Checkin! 7 01-19-2009 04:09 PM
Love my Dodge Truck!! Newbie ScotW Newbie Checkin! 10 12-22-2008 10:11 AM
