Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 4.7 Liter V8
Place your Ad Here!
Old 02-13-2011, 06:17 PM
bam2880's Avatar
bam2880 bam2880 is offline
Vehicle: 2013 dodge ram
bam2880 is on a distinguished road
Default 4.7 engine knock
hi i have a 2005 dodge ram with a 4.7 motor and i have a slight knock at idle but it stops after i give it gas what could this be
Old 02-13-2011, 06:46 PM
Resident Technician
Rep:1915
Rod bearing, main bearing, loose piston, bad wrist pin, something in the valvetrain, or something in the timing chains.
Old 02-13-2011, 06:55 PM
bam2880's Avatar
it is very slight thought should i be worried
Old 02-13-2011, 06:59 PM
Resident Technician
Rep:1915
Any type of knock short of a little piston slap on an extremely cold startup is cause for concern.
Old 02-13-2011, 07:23 PM
bam2880's Avatar
would this be covered under the 7 year 70000 mile warranty
Old 02-13-2011, 07:28 PM
Resident Technician
Rep:1915
If it's an internal failure, it should be covered.
Old 02-13-2011, 07:29 PM
bam2880's Avatar
is it common for piston slap on these motors because the motor uses no oil and has excellent power and gets good gas mileage
Old 02-13-2011, 07:30 PM
bam2880's Avatar
i wish you could give me an example of piston slap or a video to hear it
Old 02-13-2011, 07:32 PM
Resident Technician
Rep:1915
My 3.7 does it when it's below freezing outside and it's sat overnight. It's very faint and goes away when the engine warms up.
Old 02-13-2011, 07:35 PM
bam2880's Avatar
it didnt do this in the summer time and i also switched oil to like the walmart brand could this make a difference
Octane Rating (good info) Jay Fuel System 21 06-08-2011 01:02 AM
Regular gas in a 2010 ram with a hemi? Ray Dodge Ram MPG Zone 31 01-21-2010 12:04 AM
What kind of gas do you use?????? bransonshemi Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 61 12-08-2009 10:38 PM
Octane Rating (good info) Jay LD RAM - General Discussion 3 03-27-2009 08:30 AM
Cold Engine knock 95 ram 5.2 liter kccoln 5.2L V8 Specific Topics 3 02-17-2009 06:03 PM
