tonneaucovered.com
Old 02-13-2011, 07:56 PM
Dodgeramhemi09's Avatar
Dodgeramhemi09 Dodgeramhemi09 is offline
Vehicle: 2009 Dodge Ram 1500 CrewCab
Trim Level: SLT BIG HORN
Color: Deepwater Blue Pearl
Rep:51
Dodgeramhemi09 will become famous soon enough
Question right Air Pressure in 20's
Myself and a work friend both have Ram 1500 with the wrangler 275-60-20 tires...We were looking at each others truck and noticed that my tires looked more low profile than his did....Then we checked the air pressure in them...His had 43 psi in each and mine had 33....We both bought them at the same dealer ....SO, what is the correct pressure to run in these beasts?...Or is it a matter of ride comfort?
Old 02-13-2011, 08:23 PM
Netman66 Netman66 is offline
Trim Level: Laramie 4x4
Color: Inferno Red / Light Greystone Pearl
Rep:82
Netman66 will become famous soon enough
I think it's 35psi. Open your driver's door and check the sticker on the B pillar.
Old 02-14-2011, 08:50 AM
Excoastie's Avatar
Vehicle: 2014 VW Jetta GLI
Color: Metalic Black
Rep:1358
^^^ yeah, what he said
Exco
Bill
Old 02-14-2011, 04:29 PM
JTHennessey JTHennessey is offline
Rep:60
JTHennessey will become famous soon enough
Exco
Exactly what he said! Check the sticker and it will tell you what pressure you need for the tires.
2009 Dodge Ram 1500 Sport 2WD
- Lowered & Supercharged
Old 02-14-2011, 05:21 PM
916Timmy's Avatar
916Timmy 916Timmy is offline
Trim Level: SLT Big Horn
Rep:1443
35 PSI is correct. And remember that the TPMS is always a little off, mine seems to read about 2-3 psi higher than actual. Get the guage out and go! My truck also came nitrogen filled, so it's a lot more stable than regular air.
Old 02-14-2011, 07:36 PM
Rep:51
Thats exactly what I did!!....35 PSI it is....I should have known this all along to check the sticker on the door jamb.....DUH...
Thanks guys.....
Old 02-14-2011, 10:50 PM
916Timmy's Avatar
Rep:1443
You are welcome!!! Nice truck!!!!
Old 02-14-2011, 10:55 PM
Blackzilla's Avatar
Vehicle: 2009 Reg Cab S/B 4X4
Trim Level: Sport/SLT
Color: Black Pearl
Rep:199
35 psi.....
Old 02-15-2011, 12:40 PM
glamontagne's Avatar
glamontagne glamontagne is offline
Vehicle: 2009 Dodge Ram Crew
Rep:55
glamontagne will become famous soon enough
I just filled mine as my tire monitor went off in the cold weather. 35 psi is what my sticker said, and filling to 35 psi turned off the indicator light.
Gary--2009 Black Ram Crew 5.7 Truck Champ Stainless tube steps,Tekstyle Tonneau Cover, LED Interior, LED License Plate Lights, LED Reverse Lights, LED Cargos, 5900k Headlights and Fogs.
Cold air intake Gossage55 Custom Dodge Ram Performance Mods - Engine - 5.2 Liter V8 11 04-10-2011 10:31 PM
Tire Pressure Monitoring System Explained RamTech Dodge Ram Knowledge Base 4 03-14-2011 04:29 AM
Tire pressure monitor 2010Ramowner 2010 Dodge Ram Forum 3 04-30-2010 12:41 PM
Oil pressure issue HemiGTX 5.7L V8 Specific Topics 2 12-10-2009 12:57 AM
dtc po148 nachizzle Cummins Diesel Specific Topics 2 06-09-2009 12:36 PM
