Old 02-14-2011, 02:28 AM
cope1980 cope1980 is offline
Vehicle: 1999 RAm 1500 4x4
Trim Level: Sport pkg
Color: Blue
cope1980 is on a distinguished road
Question replaced engine, wont start
I just spent the entire weekend changing the engine in my truck. 1999 Ram 1500 with 5.9 engine.
Got it all installed and now it wont start. I think I may have put the flex plate or tone ring or what ever it is called, on wrong. I dont think the crankshaft position sensor is sending the timing info to the PCM properly.
I checked the sensor with a volt meter and it is opening and closing properly.
Is there a right and wrong way to install the flex plate to "time" it properly?
Thanks again in advance for the info!
Old 02-14-2011, 09:27 AM
Rep:1890
The flex plate will only bolt on one way. A DVOM isn't a good tool to check a crank sensor with. You need a lab scope so you can see if you have a good digital signal. Are you guetting fuel pressure, fire and an injector pulse?
Old 02-14-2011, 09:49 AM
Color: Blue
Yes it is firing. I do have fuel. It acts like it is trying to backfire, but it wont start.
Do you have to reset the computer to the new engine, it is still a 5.9.
Old 02-14-2011, 10:40 AM
Rep:1890
No, you don't have to reset anything but the cam/crank sync state but you have to have it running to do that. Are you positive the distributor isn't 180 degrees out?
Old 02-14-2011, 10:53 AM
Color: Blue
I lined up the timing marks on the crank shaft pulley with TDC on the timing cover then installed distributor with the rotor pointing to number 1 timing mark. While cranking engine I checked the timing with timing light and it is showing about 15 degrees before TDC.
Is it possible to get it 180 degrees out using this method?
Old 02-14-2011, 11:08 AM
sinned sinned is offline
Vehicle: 2011 Dodge Ram
Rep:5
sinned is an unknown quantity at this point
The engine balancer comes up on TDC twice per cycle...yeah, it is very easy to be be 180* out. You need to ensure the balancer is lined up on the TDC mark on the top of the compression stroke for cyl #1.
Pull the #1 plug and have someone spin the engine slowly while you have your thumb over the spark plug hole...you will know when you are TDC compression. The line up the mark and make sure the dist rotor is still pointed at #1.
If you find yourself in a fair fight, your tactics suck.
Old 02-14-2011, 11:53 AM
Color: Blue
Thanks for the help. After reading your help posts I realized that the timing is in fact out. I will fix this after work this evening. Will post afterwards. Thanks again for the help
Old 02-17-2011, 07:54 PM
Color: Blue
Thanks again for all the replys. I had a "blond" moment on this. It was late (11pm) when I installed the distributor, and the next morning I failed to double check. I assumed I had done it right . I was not sure of the tone ring, since there was NO information about it in the Haynes book except a short paragraph that said if it was not right, the truck would not start.
The truck is now running and the post inspection for the warranty is complete. 3 yr unlimited milage warranty.
Old 02-17-2011, 07:57 PM
Color: Blue
How do I reset the sync?
Old 02-17-2011, 08:32 PM
Rep:1890
You need a scan tool to do this. Use the tool to go into the set sync screen and adjust the timing as close to zero as possible.
How To: "Big 5" Basic Engine Re-Wiring Upgrade - Tutorial Valldar Dodge Ram Knowledge Base 24 05-24-2014 04:39 PM
FML! Engine surging and chugging on acceleration SanFranRamFan 5.9L V8 Specific Topics 7 02-19-2011 09:27 PM
2007 Remote start question Agent 007 Orange Dodge Ram General Discussion 5 01-04-2011 07:38 PM
My trucks flashing a P0420 and a P0442 code jcasey10 5.9L V8 Specific Topics 10 09-15-2010 02:10 PM
