Tempreture issue - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Powertrain > 5.7L V8 Specific Topics
Old 02-14-2011, 10:44 AM
adventurer's Avatar
adventurer adventurer is offline
Vehicle: 2010 Ram and 2006 Ram Hemi
Trim Level: 4x4 SLT and4X4 SPORT
Color: Silver , Flame Red
adventurer is on a distinguished road
Default Tempreture issue
Hi all , recently i changed the radiator for my new 2006 hemi ram , i didnt find radiator for 2006 model so i fitted older model radiator , everything was ok till i noticed the temp gauge goes to 3/4 then after a while goes back little bit under the middle line and not always so i went back to the shop they say there is air with water so they did take out the air from the radiator but still the same thing so i kept going to them for 3 days and every time they do the same thing (taking out the air from radiator ) so today i went and i asked them to change the radiator cap the old one was for the old radiator and written on it 16 LBS , the new one written on it 18 LBS and after the replacing till now the temp gauge reaches little little bit over the middle line and then goes down also little bit below the middle line, so is the temp now normal and was the reason for getting high temp the cap or something else ? thanks
2010 CREW CAB 4x4 - S&B CAI/87MM TB/TB GW/JET 180/OIL BREATHER FILTER/MAGNAFLOW MUFFLER DUAL IN - SINGLE OUT/CATS DELETED/HEMIFEVER TUNE/ROUGH COUNTRY LEVELING KIT/(LT285/70/17) COOPER STT
Old 02-14-2011, 11:42 AM
Resident Technician
Rep:1915
The cap could be part of the problem. When you say new radiator, do you mean out of the box new or from another truck?
Old 02-14-2011, 11:57 AM
adventurer's Avatar
Brand new out of the box but for older model as they told me
Old 02-14-2011, 12:26 PM
Resident Technician
Rep:1915
That still seems just a tad high but if the ambient air temp where you are is high, I don't think it's cause for concern.
Old 02-14-2011, 12:34 PM
adventurer's Avatar
the weather temp is around 52 f and less now days, what do you think the problem is ? so i can tell them at the shop to solve it, and where the temp gauge should be in normal situation ( middle or lower ) ?
Old 02-14-2011, 12:38 PM
Resident Technician
Rep:1915
Since you're barely getting over the halfway mark on the gauge, you don't have a big problem. You could have a thermostat that isn't functioning properly or is broken and restricting coolant flow or even reduced flow from the water pump. Was overheating the original reason for the radiator replacement or was it leaking?
Old 02-14-2011, 12:48 PM
adventurer's Avatar
it was leaking little bit , but at that time the temp gauge where barely reach the middle then directly goes below middle, it was better than after replacing the radiator
Old 02-14-2011, 12:49 PM
Resident Technician
Rep:1915
It's possible there could still be some trapped air but the Hemi isn't nearly as prone to this problem as the 3.7/4.7 engines. Are they using a vacuum pump to remove the air in the system?
Old 02-14-2011, 12:59 PM
Burkdadhemi's Avatar
Burkdadhemi Burkdadhemi is offline
Vehicle: 2016 Ram 2500 4x4 LongHorn Meg
Trim Level: LongHorn
Rep:178
Burkdadhemi has a spectacular aura aboutBurkdadhemi has a spectacular aura about
Did they install the same amount of rows for the cooling. Also there is a bleeder nut on the water pump to get the air out of the system.
2500 Megacab 4x4
Longhorn Brilliant Black Pearl 6.4L
Cattle Tan Interior
Old 02-14-2011, 01:00 PM
adventurer's Avatar
no , they only open the other hose place which is sealed with rubber and put water in radiator till the water come down from the hose exit then they close it and thats it , i know its not the right way but even at the dealer they use this way no one here have a vacuum pump to remove the air
Automatic Start Issue / Check Engine Light 07Ram 5.7L V8 Specific Topics 4 05-19-2011 06:46 PM
RUST issue with 2010 4x4 Ram Big Horn...anyone else having this issue SupermanWV 2010 Dodge Ram Forum 18 01-29-2011 10:42 PM
Vibration Issue WickedSix 5.7L V8 Specific Topics 5 01-13-2011 12:30 AM
AAC Interior Light issue Quiet Lunatic Custom Dodge Ram Interior and Exterior Lighting 8 06-01-2010 08:58 PM
Dealer issue, being a baby or honest issue. cartert1975 Dodge Ram Dealer Issues - VIN and Order Tracking - Dodge Ram MSRP & Pricing Discussion 31 04-09-2010 02:19 PM
