Tempreture issue - Page 2 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Powertrain > 5.7L V8 Specific Topics
Old 02-14-2011, 01:04 PM
adventurer's Avatar
adventurer adventurer is offline
Vehicle: 2010 Ram and 2006 Ram Hemi
Trim Level: 4x4 SLT and4X4 SPORT
Color: Silver , Flame Red
adventurer is on a distinguished road
Originally Posted by Burkdadhemi View Post
Did they install the same amount of rows for the cooling. Also there is a bleeder nut on the water pump to get the air out of the system.
yes the same amount of rows, and there is no bleeder nut on the water pump
2010 CREW CAB 4x4 - S&B CAI/87MM TB/TB GW/JET 180/OIL BREATHER FILTER/MAGNAFLOW MUFFLER DUAL IN - SINGLE OUT/CATS DELETED/HEMIFEVER TUNE/ROUGH COUNTRY LEVELING KIT/(LT285/70/17) COOPER STT
Old 02-14-2011, 01:06 PM
Burkdadhemi's Avatar
Burkdadhemi Burkdadhemi is offline
Vehicle: 2018 Ram 3500 Laramie
Color: Pearl White
Engine: 2016-20?? 409ci (6.7L) Cummins Turbo Diesel 385hp 900lb/ft (Aisin ASC69RC Automatic)
Rep:178
Burkdadhemi has a spectacular aura aboutBurkdadhemi has a spectacular aura about
There still could be air in there, It real easy to do the job. There is a allen nut on the face of the water pump and you take that out at fill you rad until there is no more air bluping out of the hole and then put the nut back in.
3500 Megacab 4x4 4:10 Gears
Laramie 6.7L Asin Trans
385Hp 930Tq
Pearl White
Old 02-14-2011, 01:17 PM
adventurer's Avatar
there is no allen nut on the water pump this is the problem , if there was one it will be easy as you say , but i really assure you that there is no one , i saw one on the 4.7 engine and i was looking at my truck but its not there,,,
Old 02-14-2011, 01:24 PM
Resident Technician
Rep:1915
If they're filling it through the upper hose, the stat will be blocking most of the coolant from going in and it would take a very long time to get the air out.
Old 02-14-2011, 01:29 PM
adventurer's Avatar
so shall i leave it as it is and the air will go alone by time or what shall i do ?
Old 02-14-2011, 02:14 PM
Resident Technician
Rep:1915
Drive it for a few days and keep an eye on the coolant and temp levels. Start with the engine cold and make sure the coolant level in the overflow bottle is at the full line and check it the next couple of mornings before starting the engine to see if it's gone down. If it has, you can assume the cooling system is pulling in coolant to replace any remaining air.
Old 02-14-2011, 02:22 PM
adventurer's Avatar
ok i ll do that and i ll report back within few days , thanks for your help
Old 02-15-2011, 11:12 AM
adventurer's Avatar
Default To RamTech Urgent
today the temp was so high so i went to replace the thermostat but couldnt find new one so they did two small holes one on each side of the thermostat and fit it back again , the temp now barely reach the middle , so is it ok to keep it like this ? is there any damage ? or shall i order new thermostat , please advise me , thanks
Old 02-15-2011, 11:13 AM
Resident Technician
Rep:1915
I'd put in a new one.
Old 02-15-2011, 11:37 AM
adventurer's Avatar
Thanks , i will order new one and report back when its fitted
Automatic Start Issue / Check Engine Light 07Ram 5.7L V8 Specific Topics 4 05-19-2011 06:46 PM
RUST issue with 2010 4x4 Ram Big Horn...anyone else having this issue SupermanWV 2010 Dodge Ram Forum 18 01-29-2011 10:42 PM
Vibration Issue WickedSix 5.7L V8 Specific Topics 5 01-13-2011 12:30 AM
AAC Interior Light issue Quiet Lunatic Custom Dodge Ram Interior and Exterior Lighting 8 06-01-2010 08:58 PM
Dealer issue, being a baby or honest issue. cartert1975 Dodge Ram Dealer Issues - VIN and Order Tracking - Dodge Ram MSRP & Pricing Discussion 31 04-09-2010 02:19 PM
