Old 02-15-2011, 11:34 AM
knsram knsram is offline
Vehicle: 2011 Dodge Ram 3500 Crew Cab
Trim Level: Laramie 4x4, 3.73gr
Color: Deep Pearl Red
Rep:20
knsram is on a distinguished road
Originally Posted by Ram15002ndgen View Post
... I have thought about doing the same but have not found a good way to secure it on mine.
It's easy to secure. I got the smallest bungee cords made. Must only be 6-8mm thickness x 6" long. There's plenty of places to latch the bungee cords to. I also added a 1" wide Mini metal binder clip to latch the top center edge of screen to the back plastic cover that runs along the top front edge of radiator just below the hood latch which helps keep the screen from saggign down.
knsram
2011 Dodge Ram 3500 Laramie Crew Cab 4WD Dually LB
Old 02-15-2011, 11:42 AM
Rep:20
....I can see why you need it, your grill is wide open.
I had thought about getting a different tighter grill, but then thought best to keep it to maintain good air flow especially now since I added the sreen. And I'm happy with the look of the aluminum screen in the back ground of the grill.
knsram
Old 02-15-2011, 03:14 PM
Ram15002ndgen's Avatar
Ram15002ndgen Ram15002ndgen is offline
Vehicle: 97 Ram 1500
Trim Level: Laramie SLT
Rep:55
Ram15002ndgen will become famous soon enough
Thanks for the advice KNSRAM, the only problem is my grill is attached to the hood rides up when I open the hood. If it was fixed like the newer Rams it would probably be easier to install, but I have little to grab it onto on my grill. Then if I attach it to the frame, I fear it may rub the A/C coil and cause problems there. I have to give it more thought is all.
www.beatcraigslist.com - for posting dangers & secrets
Old 02-15-2011, 09:08 PM
Rep:20
Originally Posted by JHamilton View Post
Awesome truck Maddog. It's large and in charge.
lol... I put an antenna on tonight. I do have a Mufflex kit on the way.
I like that quote "large and in charge". Might have to put that on my license plate frame
knsram
Old 02-15-2011, 09:12 PM
Rep:20
Just got my Torklift tie downs today. Soon as weather permits, going to install them...rain rain rain. They say no drilling required...hope so! Best prices I found are from tweetys.com. Total cost for all four was $349 and no shipping fee and great customer service! Wish me luck!!
knsram
Old 02-16-2011, 11:44 AM
Rep:20
Today truck is at Les Schwabs for installation of Ride-Rite air bags. Opt to have them leave as manual air inflation with valves placed at bottom ends of rear bumper for now. They wanted too much for air suspension compressor system added so that will be another project I can tackle later. Want to get the heavy duty system with dual gauges. I figure I will just tee-off from existing air lines to bumper to the compressor system and that way I will then have both in-cab and outer means of adjusting air.
knsram
Old 02-18-2011, 05:01 PM
Rep:20
Talking Reflex Bedliner
Just got my bedliner done with "Reflex" spray-in bedliner. They did an excellent job. Impressed with 3/8" thickness. Very tough yet rubbery enough to prevent sliding and/or scraping. Although still considering adding additional removable rubber matt before loading camper.
knsram
Old 02-18-2011, 05:09 PM
Rep:20
Thumbs up
Now I'm gong to add some Bull Ring Retractable Tie Downs!!
knsram
Old 02-18-2011, 05:23 PM
mrroader14 mrroader14 is offline
Vehicle: 2011 dodge ram 1500
Trim Level: outdoorsman
Color: deep water blue
mrroader14 is on a distinguished road
nice job on the screen, great idea, i think i will do the same. sanx
Last edited by mrroader14; 02-18-2011 at 05:27 PM. Reason: wanted to point out what i liked
Old 02-18-2011, 05:47 PM
Rep:20
Thanks..I'm quite pleased with it and it only cost me $13.00 in total materials. Let me know if you have any questions.
knsram
Ok we saw your trucks now lets see some other rides hemiv8dodgeram1500 Off Topic Discussion 139 08-18-2011 07:41 AM
New projects with Rocky RockyRam Custom Dodge Ram Interior Modifications - Custom Audio / Video 30 04-04-2011 09:13 PM
Different Projects wermbang Other Vehicle Discussion 2 11-16-2010 01:38 PM
Senators Raid Troop Funding for Pet Projects, Watchdog Groups Say sincebeen Off Topic Discussion 5 10-17-2009 10:19 PM
