Old 02-18-2011, 08:03 PM
Ram15002ndgen's Avatar
Ram15002ndgen Ram15002ndgen is offline
Vehicle: 97 Ram 1500
Trim Level: Laramie SLT
Rep:55
Ram15002ndgen will become famous soon enough
The Bull Ring retractable tie downs, are those the ones you put in the stake holes on the rails and they retract to be invisible? If so, I have those, I think you will love them. I got those 13 years ago so it may have been a different maker, but I didn't want the big round ones that stick up above the rails. These are flush and do a great job when needed.
www.beatcraigslist.com - for posting dangers & secrets
Old 02-18-2011, 11:36 PM
knsram knsram is offline
Vehicle: 2011 Dodge Ram 3500 Crew Cab
Trim Level: Laramie 4x4, 3.73gr
Color: Deep Pearl Red
Rep:20
knsram is on a distinguished road
Yes they are. They stay hidden until you pull them up to be used.
knsram
2011 Dodge Ram 3500 Laramie Crew Cab 4WD Dually LB
Old 03-01-2011, 07:01 PM
Rep:20
Happy it went as smooth as it did! I just intalled my Torklift mounting bracket tie downs front/rear. I was worried that they might not have fit without having to do some drilling beings they were listed for 2009+ and needed for my 2011. However, I must say, Torklift was on the ball I had the updated instrucitons for proper assymbly. There was no drilling required! The only tricky part was having to fish the bolts in one hole of the tube frame and out another with only the threads sticking out. I was so afraid I would drop a bolt inside the tubing. They provided a wire with spring at end that screwed on threads of bolt to hold on to while pulling bolt back through the hole. That part took the longest of anything. Otherwise it was a snap! Took a total of 2 and half hours. Going to pick up my camper (Host Everest) in two weeks.
knsram
Ok we saw your trucks now lets see some other rides hemiv8dodgeram1500 Off Topic Discussion 139 08-18-2011 08:41 AM
New projects with Rocky RockyRam Custom Dodge Ram Interior Modifications - Custom Audio / Video 30 04-04-2011 10:13 PM
Different Projects wermbang Other Vehicle Discussion 2 11-16-2010 02:38 PM
Senators Raid Troop Funding for Pet Projects, Watchdog Groups Say sincebeen Off Topic Discussion 5 10-17-2009 11:19 PM
