Old 06-22-2011, 06:12 PM
gkorzen gkorzen is offline
Vehicle: 2011 Dodge Ram 5.7
Color: White/Silver
gkorzen is on a distinguished road
Default 2011 Laramie 1500 Towing
I have a quick question. I am looking to tow a GVWR 8400 lb TT across mid country. I traded my 09 2500hd for the 1500 with towing package. Will this truck do it? I have added the airlift kit to the rear coils as well as some mods. I know the truck will pull but will it be stable or safe. Sorry for being so short but this is the third time I had type this before the browser froze up. I will be doing a lot of uphill and downhill towing. Do I need to upgrade the oem brakes? Any insights will be greatly appreciated.
Old 06-22-2011, 06:30 PM
What rear gears do you have? What is your tongue weight?
I suspect that you will have 3.55 gears and these will reduce your towing capacity. Also, depending on your tongue weight, you may need a Class IV hitch.
Lastly, the load rating on your tires may not be sufficient.
A load leveling device and an anti-sway hitch are also highly recommended.
The OEM brakes should be fine as long as you are in Tow/Haul transmission mode.
Old 06-22-2011, 07:04 PM
Color: White/Silver
I have 3.92 gear and a class IV hitch. I also have the sway bar as well as stabilizer bars. If you think the oem brakes will be fine then I will just hook and go. Thanks for such a rapid response.
Old 06-23-2011, 08:16 AM
wylie wylie is offline
Vehicle: 2011 Dodge Laramie 1500 CC
Rep:55
wylie will become famous soon enough
Default towing
I think you should have opted for a diesel. Would you PLEASE post your proposed route so that I can stay out of your way.
Old 06-23-2011, 09:48 AM
highlandchef's Avatar
Conventional Eccentric
Trim Level: SLT Big Horn
Rep:220
You should have no problems but I would double check the trailer brakes and the brake controller before you leave and then triple check them before the Rockies.
Old 06-23-2011, 03:12 PM
Wildcat's Avatar
Wildcat Wildcat is offline
Vehicle: 2010 Dodge Ram QC 4x4
Color: Mineral Gray Metallic
Rep:166
Wildcat has a spectacular aura aboutWildcat has a spectacular aura about
Great advice so far, and I assume you have a trailer brake controller. You will also want to monitor your transmission temps. Mag Hytec makes a extra capacity transmission pan and differential cover with cooling fins. I would recommend these. I know a couple guys towing over 8K have mentioned heat build up in the transmission and rear diff when there were hills involved. The Mag Hytec stuff eliminated heat issues for them.
I will post a link to the thread if I can find it.
Cobra CB, Dual antennas, Dodge molded splash guards, Tekonsha P2 brake controller, Weatherguard tool box, AirLift 1000 helpers springs, Line-X bedliner, B-Pillar tape removed, 35% tint front windows.
http://i842.photobucket.com/albums/zz347/kcwildcat1/Wildcatsig.jpg
2011 Ram 1500 Laramie Dash Removal rhgusman Custom Dodge Ram Interior Modifications - Custom Audio / Video 2 05-24-2015 12:33 PM
Need (comfortable) headrest - 2011 RAM 1500 daleoregon 2011 Dodge Ram Forum 15 12-26-2012 07:33 AM
2011 Ram 1500 rear-end 3:55 or 3:92 Weavs Ram Newbie Checkin! 12 06-22-2011 05:31 PM
Front receiver that would accept a winch - 2011 RAM 1500 daleoregon 2011 Dodge Ram Forum 3 05-23-2011 06:33 PM
Dodge 1500 not good for towing as advertised. TheDon 2010 Dodge Ram Forum 34 12-30-2010 11:36 AM
