Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Powertrain > Cummins Diesel Specific Topics
Place your Ad Here!
Old 02-15-2011, 10:55 AM
FastGreenCat FastGreenCat is offline
Engine: 1999-2001 359ci (5.9L) Cummins ISB 24-valve Diesel I6 230hp 450lb/ft (manual), 215hp 420lb/ft(auto)
FastGreenCat is on a distinguished road
Unhappy Engine Miss Fire Under Load
Hi, I have a Dodge 2001 Ram 2500 with a diesel engine. Resently, while traveling down a very rough road, I started to get an engine miss. I checked the codes and the problem was the MAP sensor. The wiring plug had come loose. I put it back on properly and the miss disapeared. How ever, I have now noticed that while under a heavy load (towing), the miss comes back. No codes are being generated. any ideas?
Fuel Presure is about 15 PSI during the engine miss.
Is it possible the the MAP Sensor was damaged?
Old 04-13-2011, 11:46 PM
ramvan2500's Avatar
Trim Level: SLT - 2500
Rep:141
Anything is possible. Replace the sensor for the hect of it but next time you tow be wise and drive it at a lower gear, slow or not. And when you are at a stop light put it in Neutral and keep the rpm's up to keep the engine cool. Check into a disil treatment
engine miss, map sensor
occasional random miss fire xjack 5.9L V8 Specific Topics 5 12-29-2010 09:32 PM
2006 mega cab miss fire #7 cylinder marc thorpe 5.7L V8 Specific Topics 4 11-15-2010 09:22 PM
Engine will not fire Lysdexic 5.2L V8 Specific Topics 5 08-31-2010 07:24 PM
96 5.9 rebuilt engine won't fire 9659ram Newbie Checkin! 10 08-04-2010 04:35 AM
Engine Miss Code P205 cherokeedoc Newbie Checkin! 15 04-02-2010 01:26 PM
