Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Powertrain > Cummins Diesel Specific Topics
Old 05-05-2011, 10:02 PM
OTwoRam's Avatar
OTwoRam OTwoRam is offline
Vehicle: 2002 Dodge Ram Slt
Color: Charcoal
Rep:120
OTwoRam will become famous soon enoughOTwoRam will become famous soon enough
Default No throttle in my cummins
Alright so heres the scoop. I am having throttle issues with my 97 dually. As you drive and press the pedal down it will just stop working. The truck wont shut off but it will drop to idle and you can have the pedal on the floor and nothing. If you shut the key off and then back on, the throttle will work again though. Any ideas?
Old 05-05-2011, 10:36 PM
RedRam10's Avatar
RedRam10 RedRam10 is offline
Color: Inferno Red Pearl
Rep:743
I wonder if it has thrown any codes? Does the Cummins have a drive by wire system? How many miles on your truck?
Old 05-05-2011, 11:11 PM
OTwoRam's Avatar
Color: Charcoal
Rep:120
no codes, 130k on the truck
Old 05-05-2011, 11:15 PM
RedRam10's Avatar
Rep:743
I don't remember where I was reading of another similar issue and the poster did a replacemet of some drive by wire component. I'll do a search to see what they did.
Old 05-06-2011, 01:19 AM
Vehicle: 2005 Dodge Ram 2500
Color: Mineral Gray
Rep:177
From what I've seen 5.9s hardly throw codes. I dont know much about the throttle and linkage on 2 gens but it sounds like a switch problem to me
Old 05-14-2011, 03:39 PM
02 Cummins Guy 02 Cummins Guy is offline
Vehicle: 2002 Dodge Ram 2500 4x4
02 Cummins Guy is on a distinguished road
My 02 did the same thing at 80,000 miles. It was in the fuel pump, and was common, but if IIRC, yours has a different pump
Old 05-19-2011, 10:03 PM
FIRESTARTER FIRESTARTER is offline
Vehicle: 98 Ram 2500 CTTD
Engine: 1996-1998 359ci (5.9L) Cummins 12-valve Diesel I6 215hp 440lb/ft(manual), 180hp 420lb/ft(auto)
FIRESTARTER is on a distinguished road
hello y'all.
ok. so up 94 to early 98 all cummins ram motors were powered by the bosch p7100 (pPUMP) pump which is 100% mechanical injection. there is only 1 electronic part on it, and that is the fuel shut down solenoid. if turning your ignition on and off helps, I'd check there.
the reason why you won't throw any codes is there is no way the computer know what's wrong with the pump.
130k is nothing for your motor I hope you know. and there is no drive by wire on the mechanical injected cummins, not unless you count the vacuum operated cruise control
-93 was the ve mechanical pump, 94-98 was the p7100 mechanical pump, 98.5-02 was the vp44 electronic pump and 24 valve head, 03 and up uses the high pressure common rail cp3 pump
98 12v Cummins Twin Turbo Diesel. Bosch P7100, NV4500, D80h...
Throttle Body Cleaning Procedure RamTech Dodge Ram Knowledge Base 51 12-08-2016 03:53 PM
Trasmission Help!!! bigjeff64 5.9L V8 Specific Topics 16 03-16-2015 11:49 AM
ETC Throttle Body Cleaning Procedure RamTech Dodge Ram Knowledge Base 8 01-30-2014 06:53 PM
