Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > LD RAM > Dodge Ram Forum Polls!
View Poll Results: Did you have HID problems?
No problems 43 55.13%
Yes, but I fixed it myself. 16 20.51%
Yes, and I needed professional help. 0 0%
Yes, and I gave up and yanked them out! 6 7.69%
Yes, and I'm still scratching my head! 13 16.67%
Voters: 78. You may not vote on this poll
Old 02-15-2011, 02:52 PM
Resident Technician
Rep:1915
Default HID Installation Poll
I see a lot of threads on here regarding HID problems and I'm curious how many people have put them in and had issues.
Old 02-15-2011, 03:17 PM
96RAM5.2's Avatar
96RAM5.2 96RAM5.2 is offline
Vehicle: 1996 Dodge Ram
Engine: 1995-1997 318ci (5.2L) Natural Gas V8 200hp 430lb/ft
96RAM5.2 is on a distinguished road
ive had mine for about 4 months now and i havent had any problem with em... ive got 10k
Old 02-15-2011, 03:40 PM
platinuminjected's Avatar
Vehicle: 2009 dodge ram 1500
Rep:713
no problems and i have 6k
Old 02-15-2011, 03:47 PM
col's Avatar
col col is offline
Vehicle: 2012 Ram 3500 CCSB
Trim Level: Laramie Longhorn
Color: Black & Gold
Rep:92
col will become famous soon enough
Yes but still having a small problem.Hope to get it sorted soon.
2012 3500 Cummins Laramie Longhorn CCSB | 68 RFE | Black over Gold | RaceMe Pro Tuner | Flo pro 4" Stainless Steel Turbo Back Straight Exhaust | 5'' S/S Tip
Old 02-15-2011, 04:20 PM
sk8noregon's Avatar
sk8noregon sk8noregon is offline
Vehicle: 2008 Dodge Ram
Rep:637
sk8noregon is a name known to allsk8noregon is a name known to allsk8noregon is a name known to allsk8noregon is a name known to allsk8noregon is a name known to allsk8noregon is a name known to all
This is why I haven't installed HID's yet, because this thread exists is one good sign for me that there are quite a few problems with them.
"Rocky and Bullwinkle"
Join the "Mineral Gray Metallic Ramz Group" here !
Old 02-15-2011, 11:50 PM
Resident Technician
Rep:1915
Same here. That's why I chose to go with whiter conventional bulbs.
Old 02-16-2011, 12:08 AM
Rep:3322
One issue I had was getting the correct bulb! No issues with the install, but the fogs have minor flare issues when running for a while, aside from that, love my HIDs.
Old 02-16-2011, 02:55 AM
sullivan's Avatar
sullivan sullivan is offline
Vehicle: 2006 Dodge Ram Sport 5.7
Rep:202
sullivan has a spectacular aura aboutsullivan has a spectacular aura aboutsullivan has a spectacular aura about
No issues, just installed 5k HID's in my fogs and in my Halo projectors. Photos will be up tomorrow.
Install consisted of DDM kits, Fogs were plug and play. Lows for Headlights required a harness. Simple easy install. No issues, no flicker.
What you guys need to understand, and what I have learned. Dodge trucks use a "can-bus system" which therefore means you need to fix your HID system using one of three ways. Using resistors, capacitors, or ultimately the best a harness. The lights are not meant to be plug and play on our trucks unless you buy a kit made just for our trucks. But you can use the cheaper alternatives and make them work! Using capacitors isn't recommended. When you turn your truck on, these capacitors just draw power and charge them up. From what I have been told, our trucks aren't meant to handle that jolt of power required for the capacitors on the power on. Therefore using a harness is suggested from what I have been told.
06' Sport - 3.92 Gears - Superchips - Bilstein Shocks - HellWig Anti-Sway Bar - Cooper Zeon LTZ - Viper Alarm & Remote Start - Halo Projector Lights - 5k HID Lows & Fogs - Custom Emblems - Magnaflow - CAI
Old 02-16-2011, 07:55 AM
Dennyboy's Avatar
Dennyboy Dennyboy is offline
Vehicle: 1999 regular short box sport
Rep:140
Dennyboy will become famous soon enoughDennyboy will become famous soon enough
Had a surging and diming problem with my fog lights. They wheren't the best set but look nice. I ended running relays to my lows and fogs, they look much better and don't dim or flash.
Dakota County Technical college
Auto Tech apprentice
cataclysmic perverter
If you don't stand behind our troops, PLEASE feel free to stand in front of them.
Old 02-16-2011, 08:53 AM
Resident Technician
Rep:1915
The CAN bus isn't really the issue because the modules aren't communicating with the headlights over the data bus. You do make a good point about the kits not truly being plug and play unless they're specifically designed for one model. What do these companies charge for one of the harnesses you mentioned?
Bought new HID bulbs but have problems str8hemi Custom Dodge Ram Interior and Exterior Lighting 9 09-28-2011 02:39 PM
HID Fog Lights BorlaRam11 2011 Dodge Ram Forum 7 02-21-2011 09:25 PM
Help hid conversion kit wont work on fog lights pacificflip72 Custom Dodge Ram Interior and Exterior Lighting 22 02-09-2011 01:20 PM
HID or Silverstar Ultra bigralphy 2011 Dodge Ram Forum 4 01-28-2011 08:29 PM
Katzkins Leather Seat Upgrade Installation Write-Up Part 1 DoubleARS Custom Dodge Ram Interior Modifications - Custom Audio / Video 0 11-29-2010 09:19 PM
