Having trouble with my driver side low beam - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Interior and Exterior Lighting
Old 02-15-2011, 03:48 PM
SapperRam1500 SapperRam1500 is offline
Vehicle: 2006 Dodge Ram
Color: grey
SapperRam1500 is on a distinguished road
Default Having trouble with my driver side low beam
The driver side low beam on my projector headlights went out. I replaced the bulb and it worked for less than a day. I troubleshot everything i could think of and came up empty handed. I upgraded to HID projector headlight assemblies and still no driver side low beam. Its not the assembly or the bulb. I cannot find the fuse or the relay cause there is not one labeled on the fuse box....can someone give me any helpful advice...
Old 02-15-2011, 03:58 PM
Diesel5182's Avatar
Diesel5182 Diesel5182 is offline
Vehicle: 2005 Dodge Ram 2500
Color: Charcoal
Diesel5182 is on a distinguished road
maybe a ground problem?
Old 02-15-2011, 04:06 PM
Resident Technician
Rep:1915
The low beam high side driver is built into the TIPMCGW and there is no serviceable fuse or relay. If you aren't getting voltage to the light with low beams selected, your TIPMCGW is probably bad and will need replacing. Of course you could always wire in a relay to power the left low beam and use the right side low beam wire to turn on the relay.
Old 02-15-2011, 10:10 PM
Extra Arm Extra Arm is offline
Vehicle: 2009 Dodge 1500
Extra Arm is on a distinguished road
If you had a burnt bulb you may just need a code cleared.
If there is a burnt bulb the TIPM senses this and shuts off voltage to that bulb until the bulb is changed and the code is cleared. You can try disconnecting the battery and touching the two cables together, or take it into a shop and have them clear it.
Passenger side Low Beam out, both High Beams work... Replaced bulbs, same. Jasser Electrical 16 02-01-2012 12:32 PM
2005 ram 1500 a/c duct hot air from passeger side witha/c on cool air driver side duc kscot Heating & Cooling 5 08-27-2011 08:48 PM
Driver Side Sagging Jovan Suspension 1 09-18-2010 07:31 PM
04 drivers side low beam trouble Tebos04 Electrical 3 08-18-2010 11:14 PM
driver side door speaker problem Quiet Lunatic Custom Dodge Ram Interior Modifications - Custom Audio / Video 3 06-12-2009 12:59 AM
