Old 02-15-2011, 03:50 PM
duffman duffman is offline
Vehicle: 2004 Dodge Ram
duffman is on a distinguished road
Default 5.7 auto tranny
Im running an 04 half ton with the 5.7 auto tranny. the truck has power to spare, but it doesnt seem to make it past the transmission. i haul about a thousand pounds of tools in it on a daily basis, and it seems like it should have a lot more snot in the higher gears than it does. this is the second auto dodge i've had and i'm on the 5th tranny between the two of them, so i'm still not a fan of the autos in these trucks.
anyway, once in a while the tranny will kick down under a load, but not a full gear, only changing RPM by a few hundred. i've asked a few mechanics about this and i keep hearing about an additional clutch in the torque convertor in these things to help save on gas. im not too knowlegeable about the auto trannys, but to me it seems like the clutch is'nt grabbing when it should be.
maybe this is normal for these trucks, but it's getting old driving the damn thing everyday
am i making this up or did i just get a bad egg?
Old 02-15-2011, 04:03 PM
Rep:1845
What gear are you kicking down from? The 545RFE has two overdrive gears plus the lockup converter. If the converter is unlocking, you'll only see a slight increase in RPM.
03' Dodge Ram 1500 4.7L Magnum - TRANNY PROBLEM - Did the shop screw my tranny up? emodpro 4.7L PowerTech V8 Specific Topics 3 09-16-2010 03:53 PM
Looking to buy a 94 1500 4x4 Auto....Tranny? NickT1271 5.2L V8 Specific Topics 1 05-07-2010 02:13 PM
New tranny and eng. t-stat, but odd temp behavior glostamann 5.2L V8 Specific Topics 1 03-13-2010 03:08 PM
03 Ram auto tranny problems 4play 5.9L V8 Specific Topics 1 02-16-2010 02:25 PM
Switching Tranny from Auto to Stick. USMCram 4.7L PowerTech V8 Specific Topics 3 01-06-2010 09:22 PM
