tonneaucovered.com
Old 02-15-2011, 03:54 PM
sixwheeler sixwheeler is offline
sixwheeler is on a distinguished road
Default 4WD Low?
So i start with the car in 2wd. I can switch to 4wd high whenever with no problem or noise. The i go into 4wd low and it sounds like the trans is droping out from under the truck. then i go back to the neutral and it goes fine, but when i go to 2wd it sounds like the trans is dropping out again. Any answers?
Old 02-15-2011, 04:00 PM
col's Avatar
col col is offline
Vehicle: 2012 Ram 3500 CCSB
Trim Level: Laramie Longhorn
Color: Black & Gold
Rep:92
col will become famous soon enough
Are you trying to put it into 4wd low when moving ??
2012 3500 Cummins Laramie Longhorn CCSB | 68 RFE | Black over Gold | RaceMe Pro Tuner | Flo pro 4" Stainless Steel Turbo Back Straight Exhaust | 5'' S/S Tip
Resident Technician
Rep:1911
How are you shifting into low? You should be rolling along about walking speed with the trans in neutral (or the clutch depressed) when you shift into low range. Once in low, pull it back into drive.
Old 02-15-2011, 04:05 PM
ok that worked. i just had it in neutral and stopped. thanks
