Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - News Desk > MOPAR NATION - Dodge Ram Club Regional Chapters! > Dodge Ram Forum CANADA
Old 02-13-2011, 01:22 PM
MountainMax MountainMax is offline
Vehicle: 2008 Dodge Ram
MountainMax is on a distinguished road
Default HID Help with DRL Problems
I have installed many HID kits (well over 100) now but my buddy wants one on his 08 dodge ram and im worried the DRL's will cause a problem, I have disabled many by blocking the headlight sensor causing the lights to come on full bright in the day, but i was told these dodges dont' have that. How can I get this to work? i have searched here already and read one person makes a kit just for the dodges to allow the drls' to work, what kit is it? how do they make them work? what is involved, please help.....Thanks in advance. Rob
Old 02-13-2011, 03:14 PM
platinuminjected's Avatar
Vehicle: 2009 dodge ram 1500
Rep:713
i dont have a problem with mine in my 09 but the kit that i bought came with a pre wired compasator and they have worked good everysince i put them in and my drl;s still work in the daytime
Old 02-18-2011, 09:47 PM
ScatPak07's Avatar
Rep:970
There is only one kit that will work with the DRLs THAT USE HID BEAM. The kit is made by Retro Solutions .I had been searching for a kit that will work for a long time and I found it finally. It is made specifically for the Ram so it works. I have not seen a kit like this one before in my life, it is really good. Definitely look at that one if you want something that will work. They also have a lifetime warranty on them which is great. The price is pretty up there but it is definitely worth it!
Old 02-23-2011, 08:39 PM
Whiplash's Avatar
Whiplash Whiplash is offline
Vehicle: 2013 1500 SLT Big Horn 4x4
Color: Black Gold
Rep:177
Whiplash has a spectacular aura aboutWhiplash has a spectacular aura about
couldn't you just use a relay setup?
dunno if it's similar in function but i remember on my stang the voltage was cut for dlr (high/low bulb) so the oem source was used as the actuator and then 12v from the battery as the true source....ya they ran all the time but with the lifespan of hid who cares??
oh, the e-brake was the ground if that matters
had no highbeam cuz of dual element bulb
just throwin' it out there..
if like on the imports the high is poweroutage cut for drl just leave 'em as is and toss the hid power where it's needed at the lowbeams
MODS: Magnaflow 16869 cat-back - S&B CAI - BakFlipG2 - Bilstein 5100s F/B - AirLift 1000 - BackRack - FT-857D/ATAS-120
next: Rims 'n rubber - That'll be it, too many electrical risks involved to go furthur
Old 02-26-2011, 02:45 PM
Murdered out's Avatar
Murdered out Murdered out is offline
Vehicle: 2005 Dodge Ram
Rep:33
Murdered out is on a distinguished road
I just did two this week one on a 2005 and a 2006
All the kits work just have to make sure its a can-bus system and i wired in some resistors for the lamp out problems
Mike
Old 03-03-2011, 01:54 AM
RT TT RT TT is offline
Vehicle: 2008 Ram 1500
Rep:46
RT TT is on a distinguished road
i sell hids reg and you can have the dealer shut this option off if you ask nicely and dont repeat it to many times..... have the dealer set country code to us then drl off country code back to canada had to do this on my 08 as well nvr had a lamp out issue tho but maybe the 55watt ballasts cancel that out with the higher current draw
Old 03-30-2011, 09:30 PM
Rider02 Rider02 is offline
Vehicle: 2008 Ram 3500 Cummins
Color: Gold
Rider02 is on a distinguished road
I installed the can bus system from HID Country in my ram over christmas and they worked great... until now. For a while the lights would stay on when the truck shut off in park... on all night... I have no lights now, no flickering, no low beams, no high beams. Fuse is good, not sure if the ballasts packed it in. No help from the manufacturer, will not reply emails, so much for lifetime warranty I paid over $200 for...
Old 03-30-2011, 11:27 PM
Rep:33
I wish you were closer I would take a look
So are you getting power and ground from the headlights unplugged the hid and check you have a few different fuses
let us know
Mike
leveling kit problems? jaybull Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 12 10-27-2014 12:32 PM
Bought new HID bulbs but have problems str8hemi Custom Dodge Ram Interior and Exterior Lighting 9 09-28-2011 03:39 PM
Help hid conversion kit wont work on fog lights pacificflip72 Custom Dodge Ram Interior and Exterior Lighting 22 02-09-2011 01:20 PM
fuel problems dieselonroids Cummins Diesel Specific Topics 4 10-09-2010 10:29 PM
any common problems for 00 ram 1500 5.9? mmoore0219 5.9L V8 Specific Topics 12 06-28-2009 04:08 PM
