Place your Ad Here!
Old 02-15-2011, 06:09 PM
steelman512 steelman512 is offline
Vehicle: 2002 Dodge Ram 1500 SLT 5.9L
Rep:27
steelman512 is on a distinguished road
Default Need help with 3" Rough Country Suspension lift
So I got my Rough Country 3" lift for my 02 Ram 2wd. It's the front coil springs, 4 Nitro shocks, blocks, and U bolts for the rear.
http://www.roughcountry.com/dodge_2wd_02-05_3.html
I can't find a good step by step for doing this and rough country didn't provide any instructions. I viewed the instructions for the 6" lift, but this wasn't much help. I need to be able to pull the old spring and shock, which will be replaced. Anyone have good but brief step-by-step of what needs to be disassembled and in what order? Its looking like I need the coil spring compression tool from Advanced Auto in order to get this new (larger) spring in place
Thanks
B
Old 02-18-2011, 06:10 PM
bigboytruck6's Avatar
bigboytruck6 bigboytruck6 is offline
Vehicle: 2004 Dodge Ram 1500
Rep:51
bigboytruck6 will become famous soon enough
your pretty much just going up to step 8 and then step 13. When I did mine I took off the caliper, rotor and sway bar links.
2004 Dodge Ram 1500 SLT 4.7
>l< Mods >l< Smoked LED Taillights / Line-X Bed Spray / Ranch Hand Tool Box / KMC XD Series Addicts/Nitto Terra Grappler/Daystar 2" Level Kit / Custom Painted Grill and Bumpers / RC Hydro 8000 series shocks / KC HiLites SlimLite Series Lights / 2 12" Sony Explods + 1300 Watt Sony Amp / Viper SmartStart / Oracle Interior LED Map Lights / Train Horn System / Hornblasters PA and Siren system
Old 02-20-2011, 04:15 PM
ncffp163 ncffp163 is offline
Vehicle: 1999 Dodge Ram 4X4
ncffp163 is on a distinguished road
steelman,
You can go on RC's website and download the instructions. They are a lot clearer on there.
http://www.roughcountry.com/install/376H.pdf
I'm putting the 3" lift kit on my 99 Ram 1500 4x4. the problem I'm having is trying to get the lower control arm cam bolts without having to cut and replace the bolts. The bolts are way expensive!!
Eric
Couple Rough Country 4" Lift Questions MOPAR MULiSHA Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 25 07-28-2011 10:55 PM
Rough country 5in lift? zmer550 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 9 01-02-2011 04:24 PM
2.5 spacer lift rough country tuckertrucker Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 4 11-15-2010 09:16 PM
rough country 3" lift??? countryboy85 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 19 08-15-2010 01:13 PM
Biggest tire with a 3" suspension lift?? StormTrippinFiVe9 Dodge Ram Wheels And Tires 5 08-11-2010 10:17 PM
