Old 02-15-2011, 06:22 PM
sixwheeler sixwheeler is offline
sixwheeler is on a distinguished road
Default Plenum Gasket
so i am going to change the plenum gasket. so what is a good gasket and what other gaskets should i change and what are some other things should i change out? thanks
Old 02-15-2011, 07:30 PM
sinned sinned is offline
Vehicle: 2011 Dodge Ram
Rep:5
sinned is an unknown quantity at this point
Just get a lower plenum gasket kit from the Dodge dealer. It comes with everything you will need gaskets wise.
I would also recommend replacing the water pump by-pass hose. They are super cheap and too easy to damage during the removal process.
Its also WAY easy to perform a complete tune-up while the intake is off anyways. Might as well get a cap, rotor, and set of wires while your there.
If you find yourself in a fair fight, your tactics suck.
Old 02-15-2011, 09:29 PM
so is this what im looking for http://www.hughesengines.com/Index/p...z&partid=23915?
Old 02-16-2011, 12:47 AM
Rep:2657
Hughes gasket kit is the best, or so i have heard
Old 02-16-2011, 07:42 AM
Rep:1890
Originally Posted by sixwheeler View Post
No, you don't need head gaskets. You just need an intake gasket kit.
Old 02-16-2011, 02:24 PM
so should go with this one?
http://www.hughesengines.com/Index/p...p?partid=26190
Old 02-17-2011, 08:16 AM
98redbull2's Avatar
98redbull2 98redbull2 is offline
Vehicle: 2014 RAM 1500 4x4 HEMI express
Trim Level: express blacktop
Rep:52
98redbull2 will become famous soon enough
that one looks ok but you dont absolutely need a new plate and hardware just the gasket will do fine, you can get just those same gaskets at the auto part store for 25 bucks.
REDBULL: Red 1998 Dodge Ram 1500 SLT Laramie, 5.2L
Old 03-02-2011, 10:05 PM
TLars's Avatar
TLars TLars is offline
Vehicle: 1998 Ram 2500 4wd
TLars is on a distinguished road
From what I'm reading on *************** - unless you want to run the risk of the standard gaskets to fail AGAIN...the Hughes plenum plate would take care of the issue. If anything it can buy a lot of peace of mind that its done and won't return, if you're thinking long term ownership.
Mods: Superchips; Spectre CAI; Magnaflow duals; 180* thermostat
Old 03-03-2011, 11:19 AM
sdram03's Avatar
sdram03 sdram03 is offline
Vehicle: 2014 RAM 3500 Big Horn
Color: Maximum Steel
Rep:52
sdram03 will become famous soon enough
i would add, the bypass hose can be a real pain if it goes out later and you gotta take everything apart again. don't ask....
which reminds me, i think i shall be doing the same kind of tune-up as soon as i get my Hughes plate. thank you for the reminder
if you're gonna go, go with a smile!
2014 RAM 3500 Big Horn CTD CC 4wd in Max Steel
Old 03-07-2011, 11:26 AM
ryano13 ryano13 is offline
Vehicle: 2002 Dodge Ram
ryano13 is on a distinguished road
had a real quick question about the plenum. I have a 2002 Dodge Ram 5.9l, I have read on the forum about the different signs of a bad plenum...and believe that is one of my problems. The only answer I couldn't find is...would a bad plenum affect the oil pressure?
Any help would be appreciated.
Plenum gasket replacement??? DJ7211 5.2L V8 Specific Topics 15 02-25-2011 12:49 AM
plenum gasket location? jaydubbz1019 5.9L V8 Specific Topics 2 01-17-2011 11:56 AM
just a plenum gasket or possibly more? dirty97ram 5.2L V8 Specific Topics 1 11-30-2010 02:14 PM
What to expect from a plenum gasket fix? Codey Custom Dodge Ram Performance Mods - Engine - 5.9 Liter V8 2 11-21-2010 10:40 PM
Plenum Gasket Leak? Sledneck 5.2L V8 Specific Topics 3 09-11-2010 12:07 AM
