MOPAR DECALS
Old 03-07-2011, 12:41 PM
sdram03's Avatar
sdram03 sdram03 is offline
Vehicle: 2014 RAM 3500 Big Horn
Color: Maximum Steel
Rep:52
sdram03 will become famous soon enough
i don't know how it could affect oil pressure. unless it was getting a ton of oil up in there and there isn't much oil in the pan, which is causing a different reading. but i'm not for sure.
there are guys on here that have dealt with it more than i that should be along shortly to get ya the needed info.
i get to rip my intake off soon and i'm gonna do the Hughes plate, just to stave off the possibility of that problem (or any other plenum issues) showing up.
if you're gonna go, go with a smile!
2014 RAM 3500 Big Horn CTD CC 4wd in Max Steel
Old 03-07-2011, 01:19 PM
ryano13 ryano13 is offline
Vehicle: 2002 Dodge Ram
ryano13 is on a distinguished road
My truck has all the signs of a bad plenum, but it also has low oil pressure...or so the gauge says. I think I am just going to get the FI Air Gap, and call it a day, if it is the plenum.
Old 03-07-2011, 07:10 PM
Well I checked the plenum, and it definatetly is bad. There is oil all on the inside of the throttle body.
Old 03-07-2011, 08:03 PM
sdram03's Avatar
Rep:52
good call! have some good ole fun swappin parts.
Old 03-07-2011, 08:23 PM
dodgeman9859L dodgeman9859L is offline
Vehicle: 1998 Ram 2500
Trim Level: SLT 4x4 QC
Color: Dark Red
dodgeman9859L is on a distinguished road
My truck burns about 2 to 3 quarts of oil in 2 weeks i was hoping with all this conversation about the plenum gasket if someone would know if thats my problem and how to test for it???
Old 03-08-2011, 08:30 AM
98redbull2's Avatar
98redbull2 98redbull2 is offline
Vehicle: 2014 RAM 1500 4x4 HEMI express
Trim Level: express blacktop
Rep:52
98redbull2 will become famous soon enough
while ur truck is running take off your oil fill cap and put your hand over the hole if it has a little suction or you can hear air sucking through the hole then its bad, also open up the flaps on your throttle body and look down inside your throttle body with a flashlight if theres oil in there then its probably bad.
REDBULL: Red 1998 Dodge Ram 1500 SLT Laramie, 5.2L
Old 03-08-2011, 07:49 PM
Color: Dark Red
well it does have quite a bit of suction actually with the cap off. do u kno y it creates suction there?
Old 03-09-2011, 08:50 AM
98redbull2's Avatar
Rep:52
the holes that the pushrods go through, wich are right underneath the valve cover go to the valley where the intake is, wich the plenum pan is on the bottom of. when the engine is running and it is sucking air into through those holes and where there is a leak its gonna create a vacuum wherever the leak is and create a suction underneath the plate instead of inside the intake, it sucks air along with the oil from the valley where the leak is and usually creates a puddle of oil in your intake and that is allways why alot of people use 2 or 3 quarts in two weeks lol, usually when its realllly bad. remember look down through the throttle body with it open and if theres oil pooling at the bottom thats usually a for sure sign the plenum gasket is bad.
Old 03-09-2011, 11:31 PM
Color: Dark Red
thanks ill have to check that tomorrow. i wasnt sure cuz my valve cover has a stock breather so i figured it was supposed to have suction.
Plenum gasket replacement??? DJ7211 5.2L V8 Specific Topics 15 02-25-2011 01:49 AM
plenum gasket location? jaydubbz1019 5.9L V8 Specific Topics 2 01-17-2011 12:56 PM
just a plenum gasket or possibly more? dirty97ram 5.2L V8 Specific Topics 1 11-30-2010 03:14 PM
What to expect from a plenum gasket fix? Codey Custom Dodge Ram Performance Mods - Engine - 5.9 Liter V8 2 11-21-2010 11:40 PM
Plenum Gasket Leak? Sledneck 5.2L V8 Specific Topics 3 09-11-2010 12:07 AM
