Old 02-15-2011, 10:25 PM
Matt B's Avatar
Matt B Matt B is offline
Color: Inferno Red
Matt B is on a distinguished road
Default NightRider Plasmaglow Tailgate bar problems
I tried to hook my TGB up to the 7 prong tralier adapter and when i hit my brakes it does not scan. it is only solid red. also if i have a blinker on when i hit the brakes the blinker switches sides... can anyone help me with this problem?
Old 02-15-2011, 10:34 PM
moparornocar72's Avatar
Rep:630
you have your wires crossed somewhere, i'll see if i can find the diagram for u
14.268 @ 95 MPH Full Trim
Old 02-16-2011, 07:56 AM
Excoastie's Avatar
Vehicle: 2014 VW Jetta GLI
Color: Metalic Black
Rep:1358
Did you hard wire it or just plug it in? If you simply plugged it in, then you might have a bad unit, if you hardwired it, you've probably got something crossed somewhere like mopar said...
I did a write up on hardwiring the other day, here is a link to it, if you wish to go that route.
good luck and keep us updated
Exco
Bill
Old 02-16-2011, 01:08 PM
Matt B's Avatar
Color: Inferno Red
Thanks alot i still would like to see a diagram im almost positive i dont have any thing crossed i think i might have to wire it into my 3rd brake light to make it work
Old 02-16-2011, 03:28 PM
Excoastie's Avatar
Rep:1358
Matt:
I've broken down what wires do what in my write up...
Black with a gray stripe is the ground
Brown is for the running and stop lights
White with a red stripe is for reverse
White with orange stripe is the left turn signal
white with the green stripe is the right turn signal
Here is a badly done diagram of the 7 pin connector. Hope it works for you, and please excuse my bad art work.
Exco
Bill
Old 02-22-2011, 09:51 PM
Matt B's Avatar
Color: Inferno Red
ill definitely have to try that but its 32 degrees out and just snowed 4 inches. so i think im going to wait until i get some better weather out here. i let you know if it helps. i also used these shitty connectors that my buddy told me to get so i think i need some better ones too.
Old 02-22-2011, 09:53 PM
Matt B's Avatar
Color: Inferno Red
and which wire do you not need because you only have 6 labels for those 7 wires
Old 02-23-2011, 10:24 AM
Excoastie's Avatar
Rep:1358
I'm not sure what the final terminal does, as I didn't need it or use it. It's not hard to trace down what wire color goes to which connector... just takes a few minutes of tracing the wires.
good luck
Exco
Bill
Old 02-23-2011, 02:03 PM
Matt B's Avatar
Color: Inferno Red
That might have been my problem i used all the connectors so i might have mixed signals confusing the bar
Old 02-26-2011, 08:34 PM
Crash's Avatar
Crash Crash is offline
Color: Deep water blue
Rep:401
Also for your brakes to scan you need to hook it to your third brake light someone here I think Ransram said there is a tan wire by your spare tire from the third brake for this purpose. Myself I put a jumper from my brake pedal to the harness for the brake controler which is that unused slot in your seven wire plug then hooked into the plug wire at the back. I only did it this way because I did not know about this wire from the third brake light. once the weather warms up I may find that wire and change it. because the jumper works but just... is... well not the proper way to do it
nightrider, plasma glow, tailgate bar, wiring problems
How-To: Installing Power Tailgate Lock iRockCrawler Dodge Ram Knowledge Base 67 03-04-2014 04:19 AM
DYI OEM rear view camera tailgate connector vyruz Electrical 5 12-25-2013 03:21 PM
Tailgate lock question ram4x4 Custom Dodge Ram Exterior Modifications - Body Mods - Body Kits 7 04-12-2012 07:19 PM
DeeZee EZ Down Tailgate Assist MightyBlueRam Dodge Ram Knowledge Base 51 01-17-2012 03:00 PM
Missing Tailgate parts? fhdavenport 2009 Dodge Ram Forum 7 09-22-2009 04:38 PM
