Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 3.7 Liter V6
Custom Dodge Ram Performance Mods - Engine - 3.7 Liter V6 Discuss modifying your Dodge Ram with Performance Parts and Accessories!
Factory Spec: 3.7-liter V6 engine - 210 horsepower, 235 lb-ft of torque.
Old 02-15-2011, 11:04 PM
haucknathan haucknathan is offline
Vehicle: 2004 dodge ram
Trim Level: low
Color: grey
haucknathan is on a distinguished road
Default 3.7 thermostat
i was wondering if any one knows if i can get a low temperature thermostat for a 04 dodge ram 3.7 v6.
Old 02-15-2011, 11:09 PM
Rep:1885
How low do you want to go? I've seen 180 degree stats available.
Old 02-15-2011, 11:16 PM
Trim Level: low
Color: grey
i wanted to go to 160 but i think 180 would be fine. iv also heard most performance parts that fit on the 4.7l will work on the 3.7l
Old 02-16-2011, 12:01 AM
Rep:1885
160 is too cold and will likely set a thermostat rationality code in the PCM. I'm not sure what parts you're referring to since there's a 2 cylinder difference.
Old 02-16-2011, 12:03 AM
Rep:4072
I'm just curious what temp you're running now with the T-stat you have?
Old 02-16-2011, 12:06 AM
Trim Level: low
Color: grey
im using the stock one. i have a throttle body spacer, intake, flowmasters, and a jet chip. im looking for more ways to gain power and or better gas millage
Old 10-06-2011, 12:25 PM
Dancianne's Avatar
Dancianne Dancianne is offline
Vehicle: 2011 Dodge Ram, Quad Cab
Trim Level: ST with combo packag
Rep:136
Dancianne will become famous soon enoughDancianne will become famous soon enough
Default Don't swap out the OEM thermostat
There are a number of good reasons for not swapping out to a lower temp thermostat:
Coolant temperature is used for a variety of engine and emission control functions. The coolant sensor on late model engines tells the computer when the engine has reached normal operating temperature. This, in turn, affects fuel enrichment, spark timing, operation of the EGR valve, purging of the charcoal canister, etc. Even on many non-computer engines, thermal vacuum switches (TVS) that react to a specific coolant temperature are used to open and close various vacuum circuits that regulate fuel enrichment, timing and emissions.
If a colder thermostat is installed, the coolant may never get hot enough to trigger the appropriate control functions in the computer or TVS vacuum circuits. As a result the engine will run as if it were continually cold, which increases both fuel consumption and emissions. Too low an operating temperature also increases cylinder wear.
Old 02-03-2012, 02:15 PM
Mysterray Mysterray is offline
Vehicle: 2003 Dodge ram 1500, 3.7lt V6
Trim Level: base
Color: Brilliant White
Mysterray is on a distinguished road
I was looking for a 180 thermostat and i found one dirt cheap @.
http://www.summitracing.com/parts/SN...3.7L%2f226
Old 02-03-2012, 11:00 PM
HemiLonestar's Avatar
Rep:274
Even if it isn't '3.7 specific' if you can't find one a stat for a 4.7 should be a bolt in.
"Big Red"
2006 Charger R/T
Thermostat question? bfinley Custom Dodge Ram Performance Mods - Engine - 5.2 Liter V8 7 02-09-2011 03:44 PM
want to replace thermostat 984wdram Custom Dodge Ram Performance Mods - Engine - 5.2 Liter V8 2 05-27-2010 02:19 PM
1997 318 thermostat ajay080672 Heating & Cooling 5 01-14-2010 08:43 PM
Thermostat Jack B 4.7L PowerTech V8 Specific Topics 4 12-14-2009 09:40 PM
180 degree thermostat works lmurry51 Custom Dodge Ram Performance Mods - Engine - 4.7 Liter V8 5 10-03-2009 08:50 AM
