Old 03-01-2011, 01:34 AM
tinniste 079 tinniste 079 is offline
Vehicle: 2005 dodge ram 1500
Color: charcoal grey
Rep:53
tinniste 079 will become famous soon enough
could be the cam slapping in your heads i know thats what happened to my 2005 the 4.7 doesnt use a cam bearing so once your cam goes your heads go that was what was wrong with mine
Old 03-07-2011, 09:19 PM
Gladi8r Gladi8r is offline
Vehicle: 2008 big horn 1500
Trim Level: Big horn
Color: Pearl black
Gladi8r is on a distinguished road
Mine does it to right on start up after a minute it goes away
Old 06-27-2011, 01:40 PM
Stormtroop 4.7's Avatar
Stormtroop 4.7 Stormtroop 4.7 is offline
Vehicle: 2003 Dodge Ram
Stormtroop 4.7 is on a distinguished road
I'm having the same exact problem as Glai8r and Spott. The ticking goes away after my engine warms up and only ticks right after start up if the engine is cold. Does anyone have a definite answer or a general idea of what could be happening?
Old 06-27-2011, 09:42 PM
SigSauer54 SigSauer54 is offline
Vehicle: 2008 Dodge Ram 1500 4X4
Color: Beige
SigSauer54 is on a distinguished road
Mine does the exact same thing for a good while after start up, was told was common and not a big deal. Had two Hemis and two 4.7s do it with no problems
Old 06-28-2011, 01:43 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
It's the lash adjusting as the engine warms up, same concept as a hydraulic lifter....as long as it goes away shortly after startup don't worry about it it's fine, if you want to be extra cautious like me, don't run the truck real hard or rev extremely high rpm until it's warm/stops ticking...
Sean
Old 06-29-2011, 01:10 AM
Thanks for the input, I was begining to get worried lol. I guess I'll keep an eye on it and see how things go. It just recently started ticking so I was a little scared for the truck.
Old 06-29-2011, 12:39 PM
snrusnak's Avatar
Rep:1385
Yeah mine will sometimes not do it, just depends I guess, what would also help with this is a good quality oil filter. Sometimes even though an aftermarket filter may fit your engine, it doesn't have the correct properties, or at least the same properties as stock. I'm using mobil ext perf and I never even researched if it is the same as stock, but assume it is or better being a quality filter. I recommend sticking with stock or high quality filters, this isn't a place to be cheap, and beware, big name does not equal big quality....fram is one of the worste filters out there, but they have marketing down pat!
Sean
Old 07-02-2011, 09:02 PM
kwatson's Avatar
kwatson kwatson is offline
Vehicle: 2006 Dodge Ram 1500 SLT QC 4X4
Trim Level: SLT Quad Cab
Rep:24
kwatson is on a distinguished road
brken exhaust manifold bolts sounds like a great excuse to bolt on some headers!
Kurt Watson - Deer Park, WA
2006 Dodge Ram 1500 SLT 4X4 quad cab
Old 08-07-2011, 09:02 AM
faststang faststang is offline
Vehicle: 2004 dodge ram
Color: maroon
faststang is on a distinguished road
Default tick sound
omg, i just found my tick sound.... broken exhaust bolt like every body talks about ,but you must take off the heat sheilds to see them mine was the top back driver side. if you take of front wheels you can get to all bolts easly..
Old 09-15-2011, 02:17 PM
dodge032001 dodge032001 is offline
Vehicle: 2003 Dodge Ram 1500
Color: RED
dodge032001 is on a distinguished road
Ok is it the oil filter,oil vis,exhaust stud,lash adjusters?I use Mobil1 engine oil,Mopar oil filter and a K&N air filter .not sure about the lash adjusters witch are $18.00 each and on the subject of the exhaust studs does the tick go away after warm up. What do I need to look for ?the tick is driving me NUTS !! but then after a few mins. it gos away and all is good .my truck run great still get 21 mph at hwy speeds
Ticking noise coming from Evap canister on Frame rail, what to do about it? HAZZARDJOHN 5.2L V8 Specific Topics 6 01-30-2012 03:51 PM
cd players turns on no sound Bigred81 Custom Dodge Ram Interior Modifications - Custom Audio / Video 4 01-08-2011 07:32 PM
Loud Whomping Sound, i'm completely stumped. Any ideas??? stlpunk13 Suspension 7 11-11-2010 03:26 PM
Engine Ticking Sound In Cold Temperatures RamTech Dodge Ram Recalls and TSB's. 19 09-05-2010 04:58 PM
Ticking/Clicking sound CoronaCrunk 2010 Dodge Ram Forum 6 07-31-2010 11:30 PM
