Old 02-15-2011, 03:58 PM
deathdealer21 deathdealer21 is offline
deathdealer21 is on a distinguished road
Default i have a question
i replaced my head unit in my 2008 quad cab with infinity speakers and replaced my door speakers with these http://www.amazon.com/Pioneer-TS-A69.../dp/B000LY8DD6 and they sound muddy, way too much bass and when i turn it up the wrods sound even worse, from what im reading i need to bypass the factory amp is there another alternative?
Old 02-16-2011, 02:55 AM
PorkChop's Avatar
PorkChop PorkChop is offline
Vehicle: 2009 ram 1500
Color: brillian black
Rep:75
PorkChop will become famous soon enough
assuming tht you have already played with the equalizer, bypassing the factoy amp seems like the best solution, your head unit will provide a much learer sound to the speaker directly.
DODGE the father RAM the daughter!
Old 02-16-2011, 03:43 AM
SslagleZ28's Avatar
SslagleZ28 SslagleZ28 is offline
Vehicle: 2002 Dodge Ram
Rep:158
SslagleZ28 has a spectacular aura aboutSslagleZ28 has a spectacular aura about
I have tried in many vehicles to use aftermarket speakers with the factory infinity amp and without special adapters it never works right. my suggestion as well is to run new wires to the new speakers, thus bypassing the infinity amp
Backlash
Semper FI
Old 02-16-2011, 11:27 PM
ok how hard is this? is there a diagram or something i can use? Do i need a new amp?
Old 02-16-2011, 11:56 PM
FormerGorilla's Avatar
FormerGorilla FormerGorilla is offline
Vehicle: 2010 Dodge Ram 4x4 Crew
Rep:147
FormerGorilla will become famous soon enoughFormerGorilla will become famous soon enough
From experience with a Nissan Maxima I once owned with the factory Infinity sound system, I was told that when you replace the system, you need to replace everything (head unit too). I don't know how true this is since I had plans to replace it all anyway (and did). The reason behind it, as explained to me, is that the impedance ratings are custom matched to the infinity equipment. If you replace the speakers, more than likely they will not be the same, making them operate on a totally different power level. Again, this is what I was told. I would imagine that if you found speakers that matched the impedance level then you would be fine. Look at the back of those Infinity speakers and see what the ohm rating is... I have a feeling it's different than the ones you bought. Mine were. Good luck!!
MODS LIST! -- 20% Tint, Curt Rec. Hitch, Slimline Toolbox, Huskyliner mats, Huskyliner Mud guards, 18" Gear Wheels, 33" Hankook ATM Tires, Bilstein 5100's at 1.4", Ported Foxbox w/2 10" Polk Subs & JL 500W Amp, Mufflex 24" Exhaust, Tow Hooks, Dominator II Step Bars, GatorHyde Spray-In Bedliner
Stereo wiring question... DodgeGuy85 Electrical 12 07-07-2013 06:57 PM
Oil Monitor Reset Question Mr. Ed Cummins Diesel Specific Topics 4 10-03-2010 07:20 PM
2/4 lowering question jjhwick119 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LOWERING or STANDARD 7 11-13-2009 08:31 PM
Question viperfella Dodge Ram General Discussion 7 08-19-2009 01:03 PM
AEM Brute Force intake question mdh3pilot Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 5 07-19-2009 01:36 AM
