Old 02-17-2011, 12:50 PM
zach99's Avatar
zach99 zach99 is offline
Vehicle: 2009 Dodge Ram 1500
zach99 is on a distinguished road
Default Tire Size
I ordered a 2.5 leveling kit from hell bent steel yesterday. And i was wondering what is the biggest size tire that will fit my stock 17" rims. The stock tires and rims are 265/70/R17
Old 02-17-2011, 03:45 PM
dankent's Avatar
dankent dankent is offline
Vehicle: 2012 Ram 2500 Crew Cab 4x4
Trim Level: Laramie Limited
Rep:32
dankent is on a distinguished road
I have read 35inch with the leveling kit is doable. but since i am doing this myself in the spring i cannot say i have done it.
Old 02-17-2011, 03:47 PM
Husker1111's Avatar
Husker1111 Husker1111 is offline
Trim Level: TRX 4
Rep:193
Husker1111 has a spectacular aura aboutHusker1111 has a spectacular aura about
i Have 35" nittos with a 2" leveling kit fits perfect no rubbing, but they are on the 20s
2010 Dodge Ram 1500 white TRX4, 2" leveling kit, Nitto Trail Grapplers 35x12.5R20, Painted stock wheels off 08 Black, 20% tint on front windows, painted to match fender flares and bumpers. University of Tampa
Old 02-17-2011, 04:29 PM
bamasport's Avatar
bamasport bamasport is offline
Vehicle: 2010 Dodge Ram 1500 Crew 4X4
Color: deep water blue pearl
Rep:186
bamasport has a spectacular aura aboutbamasport has a spectacular aura about
you should be able to fit 35" the biggest thing you have to think about would be the "stuffed look" most people with leveling kits are going with 33" because they dont want their tires to looked stuffed. just something to think about
3.92 rear axle, OEM 20" rims, 20% tint, Mopar wheel-to-wheel side steps, K&N drop-in air filter, LineX bedliner, OEM Tow hooks, Rampage Tailgate Light Bar, Borla Cat Back, 6" BDS lift, 35x12.50x20 Nitto trail grapplers, Custom painted interior, dodge slush mats
JON
Old 02-17-2011, 06:52 PM
zach99's Avatar
I have been thinking about if they were goin to look to stuffed.. I will probably go with 33". Any suggestions on brand and exact size. I would like to use my stock 17" rims.
Old 02-17-2011, 07:46 PM
vettaboy's Avatar
vettaboy vettaboy is offline
Rep:35
vettaboy is on a distinguished road
I plan on putting Bridgestone Dueler A/T Revo 2, 285/70R17 on my stock rims. Tire specs are listed as 32.8" overall diameter.
Old 02-17-2011, 09:45 PM
Momud Momud is offline
Vehicle: 2010 Dodge Ram 1500 4x4 Crew C
Trim Level: Slt
Rep:22
Momud is on a distinguished road
I believe most 35's are going to need a 8.5"-9" rim at minimum. The stock 17 inch rims are only 7" unfortunately. 33"'s are going to be a cheaper choice, otherwise you might have to get wider rims. Just my humble opinion.
I'm stuck at kinda the same place. Wanna keep the 17's but I will hafta buy some wider rims to fit some 37"s.
Tirerack has specs on their tires for what rim size is needed for the tire. Just pick a tire and click on spec when it comes up...gives lots of info on that tire and other sizes .
Old 02-18-2011, 07:55 AM
zach99's Avatar
Thanks for the info..
Old 02-18-2011, 10:52 AM
bamasport's Avatar
Rep:186
you can go with a AT tire or something more aggressive such as the cooper zeon's or nitto trail grapplers, terra grapplers. it all depends on what type of look you are going for
JON
Old 02-18-2011, 12:19 PM
zach99's Avatar
I want to go with something more aggresive.. cant really find what im looking for that will fit my stock 17"s and that is a 33" tire
Suspension, Tire, and Wheel Guide 57Hemi08 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 160 05-19-2015 09:42 PM
Tire size? CHADDER03 Dodge Ram Wheels And Tires 7 01-24-2012 12:46 PM
Tire Pressure Monitoring System Explained RamTech Dodge Ram Knowledge Base 4 03-14-2011 04:29 AM
Tire Size 01RAMguy Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 4 04-21-2010 11:37 PM
1.5 in lift max tire size RacerXisRad Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 1 11-22-2009 07:24 PM
