tonneaucovered.com
Old 02-17-2011, 02:01 PM
MikeEB76 MikeEB76 is offline
Vehicle: 2003 Ram 2500
MikeEB76 is on a distinguished road
Default Installed cab lights now no parking lights on right side
So I installed a set of aftermarket cab lights on a 03 Ram 2500. The install went pretty simple, single power to all 5 lights ran to the switch, single ground to all 5 lights ran to the dash mount. Everything works as it should with the cab lights. However, after I finished I noticed the parking lights on the passenger side no longer work. I am not completely certain they were working before, but I think they were. I did the obvious checks I could think of to no avail; ie. bulbs, fuses, taillight circuit board, dash switch.
Any other ideas for things I could check? Part guy at Dodge mentioned they have alot of trucks come back in with a integrated power module go bad that causes irregular light failures. Is there a way to test the module without replacement? Buying a $400+ dollar part and hoping for the best gets expensive.
Thanks in advance,
Mike
Old 02-18-2011, 11:26 PM
It sounds like it could be the module . Check and see if you have power to any of the bulbs . Also check all fuses too . Stop by the newbie section also . If you could go to the top of the page to the User Cp and complete your profile that would be great . Helps us see what you have when your posting a question or comment .
Which wire to tap into from parking lights to add fog lights?? sc2178 Custom Dodge Ram Interior and Exterior Lighting 4 02-11-2010 08:53 PM
Fog lights/parking lights always on 1st gen boy Electrical 8 01-12-2010 06:25 PM
02 Ram parking lights not working golfvol Electrical 1 10-24-2009 01:25 AM
another trailer lights problem scbachman Newbie Checkin! 3 06-09-2009 07:55 PM
remote start problems dendiaz Electrical 3 12-19-2008 06:25 PM
