Old 02-17-2011, 01:45 PM
LineCutter LineCutter is offline
Vehicle: 2011
Trim Level: laramie
LineCutter is on a distinguished road
Default Rear Diff Recall #10V656000
Found you guys when doing some research for my next truck. Considering a new Ram QC 1500 Laramie as one candidate. I did a search on this site for the following, but couldn't find the answers, so.......I noticed that 1 of the 2011 recalls is for a potential rear bearing failure for 2011 build between Oct - mid-Dec 2010 (see recall # above). Talked to a Ram service manager and he said the "fix" for those trucks is to over-fill the rear differential with grease by adding it to the vent in the top of the diff!
Questions:
- What happens down the road when someone doing service on the truck "didn't get the memo" and fills the diff to the bottom of the inspection hole like we have done since the beginning of time?
- Do the trucks that have been built since mid-December 2010 have a new rear diff casting with a higher location for the fill hole (front right on rear diff), or are they just over filling the diff with grease from the factory or has there been some other fix?
Thanks
Old 02-17-2011, 10:01 PM
Vehicle: 2011
Trim Level: laramie
Nobody?
I suppose a person could crawl under the fresh-off-the-transport rams being delivered and see if the fill holes are located in the same spot, and if they are, remove the plug to see if grease runs out. ??????????
Or might there be a tech/engineer on the board here that could shed some light?
Old 02-17-2011, 11:18 PM
Rep:1909
Although it's an RRT and not a recall, what the manager told you is right.
Old 02-18-2011, 07:14 AM
Al E. Gator's Avatar
Al E. Gator Al E. Gator is offline
Vehicle: 2014 Ram 1500
Color: Deep Water Blue Pearl
Rep:30
Al E. Gator is on a distinguished road
Grease? I thought the problem was underfilling on the assembly line and dealers were just topping them up to the normal level with 80W-90 gear lube.
Old 02-18-2011, 08:09 AM
Rep:1909
Al, some people refer to gear oil as grease but gear oil is what gets put in.
Old 02-18-2011, 08:29 AM
wjsamx wjsamx is offline
Trim Level: laramie
Rep:33
wjsamx is on a distinguished road
One can park on a steep hill or driveway to fill "level" with the hole. I've done that in the past to over-fill.
I would think it's very difficult to add 90W through the vent hole.
Old 02-18-2011, 08:31 AM
m3ziggy m3ziggy is offline
Vehicle: 2011 Ram 1500
m3ziggy is on a distinguished road
I spoke with a friend who worked at *cough* GM and she said this happens the odd time on the line. It doesn't get filled to the right level.
My question is, why are they topping it up through the vent hole. I thought you fill through the inspection bolt/hole and top it up to the bottom of that hole.
Old 02-18-2011, 08:52 AM
Rep:30
Filling through the vent hole takes less time. Any overfill is probably blown back out the vent when your differential heats up driving down the highway. I doubt anyone who's diff was filled this way has lube very much above the fill level after driving a few hundred miles.
Old 02-18-2011, 08:54 AM
Rep:30
Thanks Ramtech, to me grease is grease and oil is oil so I was confused. I was picturing a diff packed full of semi-solid grease.
Old 02-18-2011, 09:11 AM
Rep:1909
I can understand your confusion. A lot of the old timers in my area refer to it as grease, presumably because it's so thick.
Rear Locking Diff Question Incognito Dodge Ram General Discussion 9 01-17-2013 11:27 PM
Rear diff service ndgo88 4.7L PowerTech V8 Specific Topics 7 04-30-2011 08:50 PM
rear diff retainer clip found today ndgo88 Suspension 0 04-04-2010 06:07 PM
Rear Diff fluid ?? trainplanemech Custom Chassis - Drive Line - Suspension - Wheels and Tires - LOWERING or STANDARD 5 04-03-2010 09:29 AM
05 1500 Rear Diff Bearings AaronF Suspension 1 08-25-2009 12:58 AM
