Old 02-17-2011, 02:46 PM
crazybry79 crazybry79 is offline
Vehicle: 1998 Dodge Ram 1500
Engine: 1993-1993 360ci (5.9L) Magnum V8 230hp 325lb/ft
crazybry79 is on a distinguished road
Default OK....lets back up...or not
JUST bought a 1998 Ram, 360, auto, 4x4, 137k. Bought the truck with a "bad trans".
Previous owners description of problem. "I was coming home and it stopped, but it would still back up."
Pushed the truck out of previous owners garage (forward) and rolled it onto street. Put truck into reverse, and backed it on trailer. Noticed reverse seemed a bit soft, but it had enough gusto to spin the tires on the slippery/wet wood trailer deck. I needed to move the truck back a touch further. Put the truck in reverse....nothing. So, while I was hooking up the chains, I noticed it was leaking trans fluid (from where Im not sure...it was dark out, and wasn't messing with it at the time).
Now my First thought, was, hey, it broke a line (or whatnot) and its simply low on fluid. But, I shot that idea down simply because there was no forward, but yet there was reverse.....
Any common problems here? Am I thinking on the wrong lines?
I wont have the time to pull the truck into the shop until tonight, so I thought I would get comments and suggestions.
As a note of experience, I have been working on vehicles for 15 years, as a hobby, and professionally.
Obviously, I am going to locate the leak, and fill the fluid to the appropriate level, and go from there.....
Old 02-17-2011, 08:03 PM
Update: Pulled truck in. In park, nothing leaks. Also noted transmission was definatly over filled (guessing previous owner dumped mass quantities in attempting to remedy the problem). When truck is put in reverse it will now go in reverse again (no forward though) Also, trans fluid runs out by the torque converter sheet metal cover when the truck is in gear - a steady stream, not just a drip.....
Anyways, ordered a used tranny. Truck is on the schedual to come in to R&R transmission.
Any pointers on R&R of this tranny? Ive heard the crossmember can be a PITA.
I also have a 2 post hoist. Am I better off doing the job in the air, or leave it on the ground for transmission handling?
Thanx again!
Old 02-18-2011, 09:10 AM
98redbull2's Avatar
98redbull2 98redbull2 is offline
Vehicle: 1998 Dodge Ram 1500 4x4
Trim Level: SLT Laramie quad cab
Color: red
Rep:52
98redbull2 will become famous soon enough
the crossmember is pretty straight forward just 8 bolts the top ones are a little harder to get too. just need some extensions.
REDBULL: Red 1998 Dodge Ram 1500 SLT Laramie, 5.2L
Bought a new truck a few months back and nothing but problems at first! heffs03mach1 2010 Dodge Ram Forum 8 02-03-2011 10:33 PM
Turn Back Time mamasita Off Topic Discussion 23 06-18-2010 06:55 PM
Back to work: Worn out and NO Z! Big Daddy Off Topic Discussion 22 01-31-2010 02:09 PM
Legal advice? pretty important about a motorcyel sale, guy wants money back will Off Topic Discussion 15 01-31-2010 12:13 AM
IRS: Jim Press owes nearly $1 million in back taxes 1970 Charger Automotive Industry News and Dodge Press Releases 10 11-28-2009 03:39 PM
