Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 3.9 Liter V6
Custom Dodge Ram Performance Mods - Engine - 3.9 Liter V6 Discuss modifying your Dodge Ram with Performance Parts and Accessories!
Old 02-17-2011, 02:51 PM
foolioGrimz foolioGrimz is offline
Vehicle: 1999 dodge ram
Trim Level: 1500
Color: Green
Rep:56
foolioGrimz will become famous soon enough
Default motor swap ideas..
looking at different engines. Blueprint makes a 408 stoker based on the 360 block but its carbeurated. one exceeds the torque rating of the nv4500 at 510 ft lbs. and the other is right at or just above the max at 460 ft lbs. the budget stomper motor starts at 3,795.99 for the basic and $5,295.99 for the dress model which includes:
Edelbrock 750cfm carburetor
Edelbrock water pump
MSD Distributor
MSD Coil
MSD spark plug wires
Holley fuel pump
Braided fuel line
If I threw in a carbeurated motor into my truck would the computer be left on to work the speedometer?
Also autozone has a long block 5.2 for 2,200-2,600 which would fit the nv3500? A computer/harness would need to be added, as well as intake, throttle body and im not sure if it comes with injectors ect. If im going to spend 3 grand on an autozone motor maybe it'd be worth it to go with the stroker and just wait longer to afford the parts? I could afford the basic engine but i'd have to save more for transmission and any other parts. any thoughts or comments ppl?
mods-Ranch hand Brush guard, superchip tuner, 75 gal transfer tank, 4.10 gears with detroit locker, 305/70-16 BFG mudders, 2" lift, Chrome Edelbrock carb filter with throttle body mod, and a short glasspack.
Old 02-17-2011, 05:01 PM
Rep:2616
i am not really up on Chrysler engine performance & what all is needed to do what you want, either Street or Strip usage
but, you may want to look at builders near you
http://www.google.com/#hl=en&sugexp=...87990c28e8af33
i would never use any engine supplied by Pep Boys, Autozone, O'Reilly, or Advanced auto parts stores
they all use Evergreen Engine Exchange, Ltd. for their rebuilders & the BBB gives them a rating of F
i have seen to many issues using these engines & don't even think about calling them for support, they will NOT respond in a favorable way
Old 02-17-2011, 05:27 PM
Rep:1845
Don't waste your money on an Auto Zone engine that was half-ass rebuilt in Mexico. If you go reman, look at ATK or Jasper.
Old 02-17-2011, 06:39 PM
PorkChop's Avatar
PorkChop PorkChop is offline
Vehicle: 2009 ram 1500
Trim Level: sport
Color: brillian black
Rep:75
PorkChop will become famous soon enough
i say if your gonna go through the hassle of replacing the engine, go all out and put the meanest engine you can
DODGE the father RAM the daughter!
Old 02-17-2011, 10:10 PM
jcasey10's Avatar
jcasey10 jcasey10 is offline
Vehicle: 2002 Dodge Ram
Trim Level: SLT Quad Cab
Rep:869
What he said. Eventually my truck will get a new Jasper 5.9
Need some ideas Ram50Man Dodge Ram General Discussion 7 12-06-2010 11:19 AM
Homemade tonneau. Any ideas? robblue Custom Dodge Ram Exterior Modifications - Body Mods - Body Kits 7 11-22-2010 01:35 AM
Mod ideas 98sst Custom Dodge Ram Performance Mods - Engine - 5.9 Liter V8 13 08-25-2010 11:54 PM
[Mike] Cox proposes 92 ideas for turning Michigan around sincebeen Off Topic Discussion 4 09-28-2009 05:00 PM
Looking for Ideas Rovertech17 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 2 07-07-2009 01:07 PM
